New ENVE 2.2 SES with new Brake Surface
These came out two days ago and I'm surprised no one has posted them yet.
They have new brake surfaces (doesn't look that great) along with 2.2 Tubs at 281 Grams each and it looks lie 4.5 tubs at only 12 grams heavier than 3.4 Tubs at 370f and 399r.
The 2.2's should build into some really nice light wheels and if the new braking surface is any good they will stop as well.
I wasn't that impressed by 3.4's for braking but loving my new Bora's, night and day better.
http://www.bikerumor.com/2015/07/02/pc1 ... ore-104745
Hmmm... great call out. I wonder how long it will be before the entire lineup gets the upgraded braking surface.
Disagree about not looking great.. just looks like woven carbon, similar to the bora's - no?
After reading the thread on bora vs. enve, i'm quite curios as to how the bora's actually perform. I tested out the enves, and reynolds here in the NW, lots of 40mph+ decents, and i'm 200 lbs. I found the enves to be quite good (dry tests only), and better than the reynolds. But i've never tried boras - nor do I know where to demo these around Portand, OR.
To me Bora's look better as the whole rim is woven, the attraction of carbon wheels from the beginning was a uniform surface.
That's only one pic - others may look better.
You have to try the Bora's the braking really is that good and I outweigh you by a good amount...I've had 3.4's before.
- wheelsONfire
You may aswell buy Ax Lightness Stream 38 which is with molded and reinforced holes and weight is 9 grams more per rim (only).
You'll get 26mm wide rims with 38mm depth. My Tune (Mig45/Mag150) version is just under 1000grams.
Bikes:
Open *UP* (2016.04.14)
^^^ agree.
Riding SES 6.7 with Enve pads, I'm not at all impressed with the braking power in the wet.
my SES 3.4's braking surface is not bad. the SES 4.5 braking is better. the SES 6.7 is not so great. i'm using Enve pads with all...but noticed that some of the compound looks different from year to year. maybe that has something to do with it. i have 2 sets of SES 3.4...and one brakes much better than the other.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Factor LS Disc
Enve claims visible textured brake surface or not, they all performed identically. I sent these photos and they could not explain why some come out of the mold that way. Pictured below are two 3.4's, both shot with only a couple rides in. Regardless, each looked as pictured before road use. Are you guys running into the same thing?
