bearsdidit
- Shop Owner
by bearsdidit on Tue Apr 05, 2016 11:13 pm
F45 wrote:Is there a dimensional difference in the bead hook TL vs CL? If not then then the CL can run tubeless.
Also to consider is that if you trash the rims, the TL hubs are very difficult to re-build with a different rim (non Shimano) because the spokes use a threaded nut on the hub side.
I think you're right. The bead on the TL is a PITA with a clincher tire.
Skunkworks
by Skunkworks on Wed Apr 06, 2016 3:56 am
If you don't need tubeless.
GO CL and use veloplugs.
It would be the lightest option.
Plus, some people says that TL is hard to mount clincher tyres.
Some wheels have different rim shapes between TL and CL version. But I don't know shimano's too
F45
by F45 on Wed Apr 06, 2016 8:51 pm
Gajdzin wrote:Good advice. I'd better not trash the rims, then
On second thought, as long as you take care not to lose any of the nuts, you can roll threads on both ends of any spoke. So I guess it doesn't matter that much.
toiyuet
by toiyuet on Thu Apr 07, 2016 6:28 am
CEVelo wrote:I have the TLs, great wheels but wish I had gotten the CL version as i run them 100% as clinchers.
Is it difficult to get the tire fit in the rim bed properly?
