Shimano 6770 RD Capable of 36t Cassette?
allenpg
by allenpg
Just wondering if anyone has had luck with using the Shimano 6770 rear derailleur with a 36t cassette. I'm upgrading a couple of bikes to 11-speed and would love to have Di2 on my CX bike. I currently have SRAM 10-speed on that bike. I thought switching the rear derailleur pulleys/cage might work. Thanks!
-Pete
Grill
by Grill
No. Absolutely not. Not even close.
ghostinthemachine
by ghostinthemachine
According to the manual, maximum sprocket size is 28 teeth.
Shimano are *very* safe with their specs, so you may get away with a 30 or 32.
36, no chance.
durianrider
by durianrider
Ive fitted 32 6800 cassette to several bikes with mechanical 9000 RD's.
If you want big cassettes and Di2 then do what Wiggo did when he won the TDF and change out the cage or your RD.
Or run an XTR di2 rear mech. It will work now they have the proper software.
Or just run sram and you can mix and match 10 or 11 speed shifters from road to XC.
My YT channel
http://www.youtube.com/user/durianriders?feature=mhee" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Follow me on Strava
http://app.strava.com/athletes/254600
MattSoutherden
by MattSoutherden
Anyone know if a Shimano 5800 GS (medium cage) would accommodate a 36? Max listed is a 32 for those.
Snacking on carrot sticks - Where did it all go so wrong?
Finsbury Park CC
aerogurl
by aerogurl
I have a 6770 RD shifting an 11-34 XT 10s cassette. Front rings are 46/34. Works great, but I'm not sure if I could get a 36t in there.
KarlC
by KarlC
I some times use a 30T on my Shimano 6770 Di2 rear derailleur
C64 My Sixty 4 SR EPS 12
bm0p700f
by bm0p700f
Given a 9 speed xt med cage rd barely accomadtes a 11 to 34T cassette i would say no matt.
eliflap-scalpel
by eliflap-scalpel
you have to install a custom derailleur hanger , for a 36T cog
http://eliflap.it/
FIJIGabe
by FIJIGabe
Run a GS rear derailleur and maybe a longer b-limit screw to push it out further than stock. It will work.
I've run a 32T cassette on my 9000 SS derailleur, and it works well.
MattSoutherden
by MattSoutherden
Lieblingsleguan wrote:http://velonews.competitor.com/2015/03/bikes-and-tech/technical-faq/technical-faq-wide-gear-ranges-mixing-drivetrains-and-more_364350
Cool. So a GS mech looks like it does take a 36 with the b-screw wound in. And not even all the way.
I run a 36/50 + 11-28 on my cross/commuter. For more off-road use I was thinking a SRAM 1170 11-36 cassette would give a lower gear and simpler switching than going to 34 inner ring and 11-32 cassette.
Finsbury Park CC
