shlammed
by shlammed on Fri May 29, 2015 3:45 pm
fletch62 wrote:@bombertodd: I havent used Shimano since about 2006 and zero experience with disc's. The bike came from Trek head office and then the local dealer with the air in the lines. With the new levers it is apparently harder to get pressure into the line as it relies on gravity feed.
Its not the reach adjustment that concerns me, more the lack of a stroke adjustment which is supposed to be present. My levers are the newer ST-RS685 which has no adjustment that i can see. The first model had both adjustments via screws in the lever body. You should be able to see in the photos there is nothing to adjust.
I have been on Campag with KCNC & Planet X calipers, so not the best brakes, but always ran them with as little play/lever pull travel as possible.
Being that I like being able to modulate the brakes, having a nice amount of throw like you posted is great. if you have it fully engage right off the bat you loose any chance at having extra pressure modulation.
Check your car. Im sure the brake pedal moves about an inch from being slow down normally to panic stop. Your just not used to a long throw, IMO.
Curious George
by Curious George on Sun May 31, 2015 8:28 am
The other photos show how close to the bar the lever pulls back for full pressure. If you are descending in the drops with fingers on the bar and brakes, you can get your fingers caught between the lever and the bar leaving you with no braking at all.
Try pressurizing the system from the bottom up. Open the bleed nipple on the caliper and force fluid into the system with a syringe. Worked for me on the front, throw went from 2/3 to the bar to 1/3 to the bar. However I appear to have a more serious issue with a leak in the lever as the rear cannot be bleed properly, and pulls to the bar. Removing the bartape today and noticed mineral oil on the lever body
Trkorb
by Trkorb on Sun May 31, 2015 6:47 pm
Spacer kit came in for the swappable dropouts at the end of last week.
They basically push the forks out about 2-3mm either side - haven't got the new forks yet as they have to come from the USA. I'm sure this will alleviate the issue, but doesn't seem ideal.
fletch62
by fletch62 on Mon Jun 08, 2015 11:15 am
Went to the LBS and seems the fork will be a 4-6 week wait, to come from the US.
@OliverRB: 2-3mm seems like a lot of load to be placing on the fork either side. I'm not really convinced of this being a solution to the problem, more, creating further problems. Surely the fork is molded to a set structure/design and to then move it outwards 6mm will place even greater stresses on the fork in a way its not designed for?
jeffy
by jeffy on Mon Jun 08, 2015 9:27 pm
shlammed wrote:having a nice amount of throw like you posted is great. if you have it fully engage right off the bat you loose any chance at having extra pressure modulation.
i will +1 this.
on initially using the RS685 i thought "i dont like this" (the freestroke/throw). but after some use it is great. it allows you to 'grab' the lever and get a good firm grasp - in anticipation of braking. and oh the breaking of the shimano hydraulic is just bliss.
Trkorb
by Trkorb on Tue Jun 09, 2015 1:31 pm
We just got the new forks in yesterday, maybe it is not as much as 2-3mm each side now I have had a proper look...
I'll be putting in the new forks tomorrow so ill report back! (I'm off work today!
grover
by grover on Wed Jun 10, 2015 2:18 pm
I've just built up a Domane 6 series with SRAM Force 22 hydro. Rear shifting is horrible. Everything is new. Hanger is straight. I've built a lot of bikes and am usually the guy people come to to solve their problem but this has me stumped.
Can someone photograph/describe the rear derailleur cable run please?
I currently have cable outer from shifter to downtube, then cable runs bare through down tube, runs bare over guide at bottom bracket, remains bare through chainstay before popping out of chainstay into cable outer to the derailleur. There is a little aluminium insert that sits in the frame at the dropout end of the chainstay that the cable outer sits in. I am a bit perplexed about the path the bare cable takes through the chainstay though. The chainstay has a bend 3/4 of the way toward the dropout which the bare inner cable needs to negate which seems strange. If it's hitting the inside of the frame that'll be the source of my problems. Am I meant have cable outer running through the chainstay somehow all the way to the bottom bracket?
FIJIGabe
by FIJIGabe on Wed Jun 10, 2015 4:21 pm
My wife has a Domane 6 (standard). You've described the routing perfectly. I run her bike without a liner in the frame but have had no issues at all. Are you sure you haven't twisted the cables in the downtube? Can you post some photos of your current setup? I'll try to snap some photos tomorrow or Friday.
Trkorb
by Trkorb on Wed Jun 10, 2015 8:27 pm
So, new forks are in and fitted. The inserts have not changed, the fork now has an indent where the rotor originally fouled the fork blade.
So its a redesigned fork!
fletch62
by fletch62 on Wed Jun 10, 2015 11:48 pm
Is there any word as to whether Trek are going to issue a recall, or is it a case of only replacing the fork if the owner brings up the issue?
netromsa
by netromsa on Thu Jun 11, 2015 6:19 am
OliverRB wrote:So, new forks are in and fitted. The inserts have not changed, the fork now has an indent where the rotor originally fouled the fork blade.
Could you please upload a picture?
