Deda Superleggera or....
Hi all,
I've now superleggera and superleggero. Unfortunatelly superleggera isn't stiff enough for me.
I'd like to change this handlebar and stem to stiffer ones.
I wonder about:
1. Deda: zero100/zero100 performance,
2. Deda: superleggera35/ trentacinque35,
3. Fizik Cyrano
I'm looking for handlebar for campy record shifters. ( I had 3t ergonova...doesn't fit good)
What do you think about this?
I wonder about:
3. Fizik Cyrano
- in the industry
- Contact:
I think it depends on the length of your fingers. I would not like that bar shape (I have fairly big hands) but if you have short ones reaching the brake lever from the drops might be an issue.
Also try Ritchey bars, I think they have a good shape. I currently have athena shifters on old Ritchey logic Pro bars.
fifarafa wrote:Hi all,
Hi fifarafa,
Actually I wanted to use this combo also (superleggera and superleggero)....you make me unsure now as I saw that you are 75 kg (70-71 kg); almost like me with 68-72 kg...
In which situation are they not stiff enough ?
Br,
Tony
Hmm Pretty incomplete startpost.
not stiff enough? why not what you mean exactly.
What is ur weight?
What is the size of the stem
Size of handlebars.
Amount of spacers
pic
etc
Ergonova doesnt fit? in what way?
When you want that people think with you, please provide proper info.
(you can edit your startpost with better/more info)
What is ur weight?
Size of handlebars.
Amount of spacers
pic
etc
BRM wrote:With campa shifters you should end with a small dimple where bar and shifter go over in eachother.
Not sure I know what you mean by that, but my BG Fitter put them there and they feel like a level transition from bar to hood.
I originally had the Deda Superleggero/Superleggera stem/bar combo. I prefer the 3T ARX/Ergonova stem/bar combo. Better shape for my hands and stiffer.
I have the Deda Zero100SC/Presa stem/bar combo on my other bike which I also like.
It's all downhill from here, except for the uphills.
TonyMM as TheDarkInstall wrote: bars " Flexy as hell in the drops"
viewtopic.php?f=3&t=106698&hilit=superleggera&start=105
and this is true even when you compare this to ergonova team...though... superleggera is far more comfortable ... for me and beetter for my shifters
stem 120/ bars 44/ top cap 25
fifarafa wrote:TonyMM as TheDarkInstall wrote: bars " Flexy as hell in the drops"
Ok, now understood. Comfortable but not stiff enough
The whole story with the torque and the carbon doe not make feel secure
I ride quite a lot in the mountains and I need to be secure.
I suppose I will got for the Deda Zero 100 Stem/ Bar now Only + 95 gramm in total compared to Superleggera/ Superleggero.
Are you now only looking for alu stem/ bars or also for carbon bars again ?
I really like shape of superleggera (deeper than ergonova) so I'm looking for sth similar
as I wrote I'm thinking about Deda: zero100/zero100 performance or superleggera35/ trentacinque35
but I'm curious why even Greipel hasn't in Helium 35
http://road.cc/content/news/124587-tour ... -helium-sl
aesthetics, comfort?
fifarafa wrote:unfortunatelly no...I've middle hands, neither small nor large so I don't know if these bars will be good for me
I would suggest you to test these in your hands. I am sure you will say "no go" or "buy"
At my local dealer I saw them but I was not sure. As soon as I had these in my hands, I knew (no go or buy).
