dual pivot brake calipers
You may find lighter, but doubt they will be better. Why, out of curiosity do you want to change?
I think the only option is the EE brake. It's the only thing that is both lighter and not a step down in performance.
- HammerTime2
- Location: Wherever there's a mountain beckoning to be climbed
Is Fibula a step down in performance?
I generally exclude Fibulas from my first recommendations since they are price prohibitive in most cases. I don't think they are a step down from Campag in performance, but I think EE are a better install it and forget it option for a daily rider.
- Location: United Kingdom of Great Britain and Northern Ireland
I have found that if you use calipers with a QR mechanism when there is already one built into your levers, it will bug you.
And do not buy TRP 970SL or similar - they are crap. You only have to look at the little alloy screws on the underside of the caliper and they will start to corrode. Nothing like a bit of stainless steel kit like you get with Campag.
I bought a set of Ciamillos GSL micros to substitute my Campy Super record for my WW build, and they have nothing to do performance wise. Campy SR are much much better
madcow wrote:I think the only option is the EE brake. It's the only thing that is both lighter and not a step down in performance.
Do these brakes fit standard frames? I have a c59
Colnago arabesque campagnolo super record 12
Colnago c64
Cinelli zydeco grx di2
Colnago c64
Valbrona wrote:I have found that if you use calipers with a QR mechanism when there is already one built into your levers, it will bug you.
I've found the opposite. I had set of Campag super records - dual pivot front, single pivot rear. I bought them on a clearance and just got them to try out. Used them for a season, but then got annoyed that it was the only Campag part on my bike. I switched to TRP 970's, and the performance difference was huge. I'm 195 lbs, and my regular rides feature 2000-4000 ft of elevation gain/drop. It's been 3 seasons with the 970's, and I would't think of doing anything different performance wise.
Also, no corrosion that you spoke of. I had 2 seasons where I rode in VT winters, and last season in NW Oregon. Rainy/snowy places to say the least.
Mockenrue wrote:Markyboy if you decide to sell please PM me as I'm looking for a pair and I'm not far away from you.
no probs will keep you informed
Colnago c64
Colnago c64
That only can be explained by an extremely bad install of the Campagnolo brakes, or the combination of campagnolo brakes with some Shimano levers (somehow these two don't mix up too well performance wise). In every other case the Trp's are a pain to install and performance wise way beyond what you had.
