Hi,
did anybody collect experiences with the reset pf24 bb? it is fairly light with 80 gramm, but what about durability, etc.?
thanks, regards,
http://www.bikeonlineshop.net/reset/res ... f-24-rr-bb
Reset PF24 Bottom Bracket-Experiences?
- bikerjulio
PF30 by design allows for wider tolerances at the BB shell, and I can't help but think that the success of that adapter depends a lot on the frame tolerance, and method of installation. Plus I could be wrong but I thought PF30 was intended to use delrin inserts. In other words, I'd be worried about it coming loose in the frame.
This, OTOH I'd have a lot more confidence in. https://praxiscycles.com/product/shimano-conversion-bb/
There's sometimes a buggy.
One.
One.
bikerjulio wrote:PF30 by design allows for wider tolerances at the BB shell, and I can't help but think that the success of that adapter depends a lot on the frame tolerance, and method of installation. Plus I could be wrong but I thought PF30 was intended to use delrin inserts. In other words, I'd be worried about it coming loose in the frame.
me too
i had the reset bearings in my moots rsl (pf30) but experienced creaking and sqeaking without end
now have the praxis conversion for more than a year and it runs absolutely trouble free
in general, pressfit bearings sitting outside the bottom bracket shell it asking for trouble
Hi,
thanks a lot for your replies!
cracking and moving in the frame is, what i expected, considering the design of the reset-bb. thanks for your confirmation!
i use rotor 4624 at the moment, which offers much more contact face to the bb-shell of the frame. it works trouble-free as well, no loctite required, but with 137 gramm its a bit heavy (frame weighs ca 700 gr!
does anybody know the weight of the praxis adapters?
thanks, regards
thanks, regards
