Power meter vs perceived exertion
bigfatty
by bigfatty
Now it is a common site, taped over power numbers. Below is Contadors.
It is true you can build power with higher percieved excertion but with out a power meter.
With a Power meter but without higher Perceived Exercion, one will never build power.
Has anyone dropped off from measuring power and gone back to PE. Please share your experiences.
(sorry for the full caps :oops: )
admin: YOU DON'T NEED TO YELL AT US
erty65
by erty65
What if you ride with x amount of watts, and increase on your next ride, and so on. Will PE also increase?
HillRPete
by HillRPete
I don't get this perceived exertion at all. Go by hard data. Distance, time, power (if you have it).
boysa
by boysa
Training and racing are very different. Which is this picture showing?
"Deserve's got nothing to do with it." William Munny
bigfatty
by bigfatty
HillRPete wrote:I don't get this perceived exertion at all. Go by hard data. Distance, time, power (if you have it).
arguably the best Grand Tour Rider of the Modern Era seems to disagree. This is why I ask.
bigfatty
by bigfatty
boysa wrote:Training and racing are very different. Which is this picture showing?
I would suppose this is in the Giro (or there is something Cadel has been hiding from us :wink: )
So training and Racing, I guess
HillRPete
by HillRPete
bigfatty: right, let me try again. For short intervals, I think you want to primarily go after hard data. For long ones (say a climb of 10min or more) that you do frequently, you can go by feel (and which gear you're in, obviously), but you want to record the data to look at it later, and close the feedback loop. That's my approach anyway.
bigfatty
by bigfatty
HillRPete,
just to be the devils advocate here, so whilst doing a prescibred Wattage on short interval, even if you feel great, you wouldn't up the power?
regards the long climb, let's face it, if you can't get yor desired wattage, then you can' get it, simple as that, so this is why we have percieved effort.
I suppose I know when and why to use power but there must be some zealots out there who go on PE and these I would like to hear opinions.
highdraw
by highdraw
bigfatty,
Can you explain why you believe that taping over PM numbers relates to higher perceived exertion?
Why are they alternatives to one another? Curious where you got your hypothesis or even assign motive to why Cancellara taped over his PM?
5 8 5
by 5 8 5
The Pros that tape over their SRMs are normally doing so because they don't want to be distracted by the wattages shown. ie just race. They do want the data though for analysis later. The PC8 will have cusomizable fields so that watts can be hidden.
You should b looking at heart rate as an in between perceived effort and power to give quantifiable information.
To use perceived effort correctly you need a fair amount of experience to know how your body is reacting to efforts. A heart rate monitor is a good addition.
bigfatty
by bigfatty
I just thought if they are not looking at power output then they are going on PE, not that it leads to higher PE.
but it is certainly real that some Pros are ignoring there Power numbers in races.
5 8 5
by 5 8 5
bigfatty wrote:regards the long climb, let's face it, if you can't get yor desired wattage, then you can' get it, simple as that, so this is why we have percieved effort.
The crux is how accurately you can judge a perceived effort to a wattage by not going too hard or too easy which comes down to experience.
jekyll man
by jekyll man
Number fixation...
find nothing worse unless you're meant to be doing specifics.
if you're bunch racing, you either go with the moves or you're left behind...
Official cafe stop tester
highdraw
by highdraw
bf,
don't believe perceived power is alternative to blocking a PM readout...if so, it isn't expressly so but rather implicit. Rather I believe that overall riding circumstances determine rider exertion level especially if racing including how the rider feels and/or even a glance at heart rate.
It also can be an experiment on perceived power. Ride hard and then review data after the ride to see how it comports with training/racing to a power zone or target.
dgran
by dgran
bigfatty wrote:I suppose I know when and why to use power but there must be some zealots out there who go on PE and these I would like to hear opinions.
I'm not zealous about it, but I use power metering on the trainer and PE on the road. I target a few time trials (uphill) per year and do pretty well at them. I prefer this setup for several reasons:
1) I don't want to even get into the indoor vs outdoor FTP issues. I have one number and one measuring device indoors.
2) The winter is my ideal time to get structured since volume (due to daylight) has to decrease and as much as I may have rigged out my man-cave of pain, I won't devote the volume of time on the trainer like I do outdoors. It works though, because each spring I'm more fit than the previous fall.
3) I need to have a self imposed data diet. If I have a power reading all year round I will want that number moving up. I get a better mix of riding intensity outdoors with PE and chasing some Strava segments. After a winter of staring at "the number" I benefit from the mental release of just listening to my body.
4) After a certain point, "the number" isn't telling me much. After years of structured training I can close my eyes, vary my pace a bit, guess my power output and be pretty darn close. If you spend ~120 hours a year on the trainer staring at the wattage you eventually connect the dots to what each ladder feels like.
All this aside, if the 4iiis precision is as good as I expect it will be hard to pass up for $400 to add power to my outdoor bike, so I may eat my words here. Probably my big reason for going with PE is related to item #4 above where I just can't justify the expense right now.
