Toybota
by Toybota on Mon Feb 22, 2021 11:04 pm
TerryDi2C wrote: ↑Sat Feb 20, 2021 10:52 pm
I wouldn't use any regular seatpost battery holder for something like that - there are others too:
https://www.giant-bicycles.com/gb/inter ... ery-holder
adding 100mm should be ok... I'd probably go a bit longer on the seatpost battery. That wire will have to run from the junction B to the top of the seatpost and then a bit further.
(when you're taking the seatpost out or installing the battery)
Hey Terry,
Could you provide me a recommendation on installing a battery into the 3T Strada seatpost?
Would it be ok wrapping the battery with a innertube?
Thank YOu
yeahdext
by yeahdext on Tue Feb 23, 2021 11:05 pm
Toybota wrote: ↑Mon Feb 22, 2021 11:04 pm
Hey Terry,
Thank YOu
There are some genuine ones on eBay too if your UK based. Seller is Items123.
Toybota
by Toybota on Wed Feb 24, 2021 4:06 pm
yeahdext wrote: ↑Tue Feb 23, 2021 11:05 pm
Hey Terry,
Thank YOu
I'm in NA. Might have to pull the trigger if innertube hack doesn't work.
Thanks for the link.
