spdntrxi
by spdntrxi
Not here yet, but coming soon
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
ome rodriguez
by ome rodriguez
CustomMetal wrote:
Mon Feb 05, 2024 5:38 pm
ome rodriguez wrote:
Sat Dec 02, 2023 9:14 am
Thoughts?
Haven't ridden it yet, some photos.
Weight @ 1,164g
CustomMetal
by CustomMetal
Mon Feb 05, 2024 10:20 pm
Thoughts?
Weight @ 1,164g
Be very interested in a ride report when you have. Also for a report on durability as heard the spokes can be a bit fragile...
Allegra- Steel Lugs TBC
Aurelia- Stainless All Road 8.5kg
Bertha- TT 9.8kg
Perdita- Ti Turbo bike 8kg
Serenity- Ti Gravel 9.5kg/8.9kg
Verity- Ti Aero 8.2kg
Alya- Ti Climbing TBC
nickf
by nickf
nickf wrote:
Fri Dec 08, 2023 12:05 am
Alloy wheel build. Mostly for the travel bike and also for those soggy wet winter rides. Will be built up with cxray and cxsprint DS rear. Should be sub 1500g.
New Boyd cycling rims 20/24 hole. 21mm internal width.
Novatec AS511SB FS522SB hubs. These have become my go to hub. Great durability, easy maintenance, and ok weight.
Finally got these built up. Ended up using DT aerolite spokes. First ride will be in a couple of days. 1440g no rim tape and around $150 cheaper.
The factory built Boyd wheels are pushing 1620g.
spdntrxi
by spdntrxi
WS2 coated
2023 Pivot E-Vault
DogmaHiFi
by DogmaHiFi
@spdntrxi, receive my Bbinfinite coated (Ita) to replace the SRAM. Very happy with the result
DogmaHiFi
by DogmaHiFi
@spdntrxi, received my Bbinfinite coated (Ita) to replace the SRAM. Very happy with the result, straight forward easy installation
DogmaHiFi
by DogmaHiFi
@spdntrxi,
UpFromOne
by UpFromOne
Elilee X-Novanta cranks in 172.5 showed up today, so I promptly sanded down the clearcoat for a few more grams. Sorry for huge pic.
spdntrxi
by spdntrxi
^ nice I'd gladly give up some grams for a metal spindle end.. yah talking to you THM.
2023 Pivot E-Vault
chorus88
by chorus88
Special thanks to Mike C @ Specialized Canada.
Y-I-P-E!
When Technology Becomes Emotion
2023 Tarmac SL7 Expert R8100 (90622-3352)
Butcher
by Butcher
While coasting down the final climb on Zwift's climb portal, my Hammer just started to freewheel. No lights and after 5 years, it finally died. Who says things always break down at the wrong time?
I bought a new H3, shipped to my door for $552. Brand new from Saris, not complaining about the price either.
jfranci3
by jfranci3
UpFromOne wrote:
Fri Feb 09, 2024 2:04 am
Don't sand that stuff! The paint is much much softer and than the resin. When you get down to the base, the paint will move around more than the resin and you'll start removing large patches of resin but not much paint - especially at the finer grits. You'll end up with an ugly, patchy item. Use this instead - https://www.nationaltoolwarehouse.com/A ... yMEALw_wcB
kode54
by kode54
UpFromOne wrote:Elilee X-Novanta cranks in 172.5 showed up today, so I promptly sanded down the clearcoat for a few more grams. Sorry for huge pic.
That’s a nice weight. Only reason to sand was to remove graphics?
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
Kayrehn
by Kayrehn
Udog Cima with laces replaced for colour, 659g on the scale, - 86g maybe for cleats/bolts so around 573g for size 44. They list this as EU44/US10.5, and usually I wear shoes that are labeled as EU44.5/US10.5, and needed something wide at the front foot like the Bont wide version too. Luckily this is a perfect fit for length and ok fit for width (left foot is a little squished width-wise). Very low toe box volume which I like cos it adds to the 'fitting' feel, and I think laces will make it stay secure more so than boa dials. Image
Sent from my Pixel 6 using Tapatalk
