Gravel / Bikepacking / Allroad / Road Plus / Mixed Surface / Monstercross bikes
Moderators: maxim809, Moderator Team
LeMomo
by LeMomo
Here's my 3T Exploro team - 9.1kg in gravel spec - pictured on a day out in the Peak District
Exploro on a bridge
by Matt Cotterill, on Flickr
3T Exploro Team frame and fork, sz Large
3T Charlie seatpost (flipping heavy!)
3T Arx team stem, 120mm
Zipp service course SL XPLR 44cm handlebars
Lizzard Skins 3.2mm DSP tape
Specialized Power Pro Elaston 155mm saddle
Quarq DZero GXP carbon (172.5mm)
Dura Ace 9170 shifters and brakes
XT 8050 Di2 rear mech
Hope 10-44 cassette
KMC X11EL chain
XT trail pedals
Wheels
DT Swiss XM401 650B rims
Hope Pro4 front hub
DT Swiss 350 rear hub (with OneUp mini driver fitted)
Hope 160mm rotors
WTB Byway 650x47 tyres
Nejmann
by Nejmann
FlatlandClimber wrote:
Sun Jun 07, 2020 9:11 pm
Just came back from my Bike Packing vacation.
It's an Open Cycles WI.DE, mullet Group with SRAM FORCE eTAP AXS 1X 44T + Quarq DZero in the front and SRAM Eagle AXS XX1 Cassette and Deraileur in the rear. Bar and Stem are the Gravel specific ENVE parts. The wheel setup is my "summer setup" with 9th Wave Anath 700 Carbon Gravel Wheels with Maxxis Re-Fuse Tubeless 40c Tires. In Winter I ride Stan's Arch CB7 with Super wide Schwalbe RockRazor Addix 2.4Inch.
The weight is 8.4 as it is right now + semi permanent headlight from Lupine + Semi-Permanent Top tube bag + 0.8kg when I have my winter wheels on.
How do you like that enve gravel handlebar? Got a regular lying around, but is the gravel one worth it?
AndySti
by AndySti
My Alliance Ti. Love this bike!
FlatlandClimber
by FlatlandClimber
Nejmann wrote:
Fri Jun 26, 2020 5:23 am
It's very wide, especially the long Drops have huge flare. I think it is very comfortable and also good to control in rougher terrain.
Cervelo P5 Disc (2021) 9.1kg
S-Works SL8 (2023) 6.3kg
Nejmann
by Nejmann
Fri Jun 26, 2020 7:14 am
All right. Maybe I should get a size smaller than normal then.
FlatlandClimber
by FlatlandClimber
Yes, it is definitely very wide. If you want to ride your gravel like a racer, it might not be perfect. For comfort and very long rides it's perfect. But sizing down is a good idea.
zmjones
by zmjones
LeMomo wrote:
Thu Jun 25, 2020 4:06 pm
Exploro on a bridge
Hope 10-44 cassette
KMC X11EL chain
XT trail pedals
Wheels
Hope Pro4 front hub
Hope 160mm rotors
really like the color!
mcal8055
by mcal8055
Here’s my Ibis Hakka 55cm with 650b setup. 8.1kg as pictured. Image
Yemble
by Yemble
Point wrote:
Wed Jan 22, 2020 11:52 pm
I've been pining for a metallic green frame and this Rove ST frameset came up at an unrefusable price.
The green is so pretty. We must think alike - a few years ago my two bikes were a Burls and a Rove.
justRideIt
by justRideIt
My Spesh Diverge on 650b & Continental Speed Kings
2020 S-Works Tarmac SL6 Disc @ 6.35-ish kg: viewtopic.php?f=10&t=159454
2021 Specialized Diverge viewtopic.php?f=10&t=165482
icyhotchaz
by icyhotchaz
2016 Jamis Supernova Team.
Painted the fork ala Palace X EF. Currently has 38s with some room, though not certain how tight 40s would be.
Fantastic geo. Technically a CX bike but really feels like a roadie (not too high from the ground).
Weight with pedals and cages- 19.1lbs/8.66kg
cnyn
by cnyn
Some Upgrades after nearly 20.000 kilometers:
Easton crank
C-Bear BB Cross-Version
GRX Di2 Derailleur
Dura Ace STIs and calipers
XTR Cassette
7,5 kgs incl. pedals, cages, Wahoo, ready to go
PinaRene
by PinaRene
@JustRidelt ; love your Specialized ... I was going for the same model/colour - but couldn't get a right fit on the 54 or 56. The 54 was to short and I should have used a 110mm stem - on the 56 the front end was to high... bit of a bummer, but bought myself a BMC URS One size M :
There are be some changes:
* DT SWISS C1850 will be the winter wheelset with the WTB Raddler's - tubeless.
* Zipp 303S are on the bike now for the better days with Pirelli Cinturato Gravel H - tubeless
* Groupset will be Shimano GRX 810 1 x 11 ( all disc bikes here are Shimano so no oil issues with Sram then.( Originaly Sram Apex 1 x 11 ))
* Setback seatpost from BMC ( Longer torso shorter legs )
* Stem / handlebar switched from BMC/Easton to Pro Discover Carbon 20 degree flare and matching stem 80mm instead of 70mm.
So my setback / reach and stack will be almost the same as on my road bikes. Reach will be 1cm shorter I guess and stack will be 2cm higher. Old groupset had been dismounted from the bike and on it's way to the new owner.
mediocreXwizard
by mediocreXwizard
My Curve "Kevin" GXR
Not the lightest but so much fun to ride
