Forum rules
Slagter
by Slagter on Mon Apr 13, 2015 5:39 pm
pashax wrote:Rims : DT Swiss R460
Spokes : DT Revolution or Sapim Laser
Spoke count : 24/28 or 28/32
Hubs : DT Swiss 350
Nipples : Sapim Polyax (alloy)
28/32 build should be bombproof, innit?
No need for 28/32.
I'm 191 lbs at the moment, and my Bitex hubs laced to Kinlin XR19W are doing just fine in a 24/28 config after 8.000 km.
The DT 460 are both heavier and wider than my Kinlins. 24/28 is more than enough for you with that config.
mrlobber
by mrlobber on Mon Apr 13, 2015 5:45 pm
Thinking of gathering parts for a daily bad roads/gravel/occasional non-serious CX race disc clincher / possibly tubeless wheelset for my new CX bike.
Out of 3 rim options in order of personal preference (Hed Belgium+, Pacenti SL25, Stans ZTR Grail) it looks like I eventually might be getting Stans because the former 2 are not easily available for me (or cost 2x as much as Stans if shipped from abroad)
I'm a 75kg guy already for 10 years, and probably will remain there.
From hubs, nothing original at all, as good budged as possible, thinking of DtSwiss 350
Would 24F/28R be good for such a build? Most appropriate lacing pattern?
pushstart
by pushstart on Mon Apr 13, 2015 5:52 pm
mrlobber wrote:Would 24F/28R be good for such a build? Most appropriate lacing pattern?
I would suggest 28/28, if disc, as your braking forces concentrate up front (common to run a larger rotor up front too).
2x/2x or 3x/3x. I like the aesthetics of 2x the angle of spokes wrt radial torque is slightly better with 3x; in practice, it doesn't matter (at least it hasn't for me).
I have a set of 28/28 Grail wheels I use for CX (singletrack). Grails are really nice rims. They built up so nicely, easy to mount tires (easy to seat tubeless), have been bomb-proof. (I also weigh around 75kg.)
mrlobber
by mrlobber on Mon Apr 13, 2015 6:32 pm
Ok, thanks. Good point on the rotor difference too, easily to forget if running carbon road machines all the time.
bm0p700f
- in the industry
by bm0p700f on Mon Apr 13, 2015 11:33 pm
Agree with same spoke count front and reaf for disc brake wheels. For road though i always spec 160mm front and rear rotors as the brake brake is quite useful when decending and it helps it not overheat.
pushstart
by pushstart on Tue Apr 14, 2015 10:24 am
Yeah, I would use 160/160 if my frame would fit the 160. In practice the 140 in back with a good rotor (I found Avid HSX rotors to be a lot better with my Spyres than the TRP rotors) has worked fine for me, though.
MattSoutherden
by MattSoutherden on Tue Apr 14, 2015 10:52 am
I have some Pacenti SL25s 32h 3x on Novatech 771/772. If the worst you'e going to ride is some graded roads, then 28h 2x is probably fine at your weight. The advantage of more spokes is that a loose or broken spoke has a less dramatic effect on the overall wheel operation. If you take the bike off-roading out in the sticks a long way from help, then this might be of concern to you. If you taco a wheel in a cross race, it's not really a problem.
pushstart
by pushstart on Tue Apr 14, 2015 3:31 pm
Yeah, it really depends on riding style and terrain. I have no qualms riding my 28-spoke wheels on pretty rooty/rocky east-coast (US) single track. But I ride with 38c or 42c tires now to avoid pinch flats on said terrain. I am sure you could taco these wheels, though I also feel a lot more confident on them than my 28-spoke Stans Crest wheels they replaced (for reasons of hub change/thru-axle, not that anything bad happened to the Crests).
Derf
by Derf on Tue Apr 14, 2015 6:14 pm
What are people liking for budget-level track hubs? (~$50) Miche, Formula, BHS (Bitex?), Novatech, etc?
32sp--training wheels that will be actually used on the track. Double threaded would be nice (can keep both a warm-up and a hard-effort cog on the hub).
Derf
kavitator
by kavitator on Sun Apr 19, 2015 9:54 pm
Question for more experienced - how do you tesnsion sppokes on that kind of lacing?
Is same tesnion for all spokes on one side or same tension for each second spoke?
kavitator
by kavitator on Mon Apr 20, 2015 8:59 am
It is 2x on both sides
but spokes are not over/undr, they go direct from flange to rim.
In picture you can see big variation in "geometry " on same side.
So i was thinking spokes closer to center must have higher tension from spokes on outer holes of flange.
