Guys, need some explanation about Racing 1 wheels. Have a pair with black-red decals (probably 2012 or 2013 model year) with Campagnolo freehub. Need to know about conversion ability to Shimano 11-speed hub, cause I'm not a fan of mixing components (e.g. campy cassette on shimano 11-speed drivetrain).
Wheels looks like that
Any thoughts, please?
Old Fucrum Racing 1 question
Nothing to explain, you just need a freehub.
Wheels like Fulcrum and Mavic that were already cross compatible with Campag 11 and Shimano 10 freehubs were forwards compatible with Shimano 11. Only wheels where the entire hub was Shimano 10 specific had problems.
Thanks, so the 11-speed shimano freehub should suit theese wheels instead of campy one without any problem? Asking, cause 2012 FR1 was compatible with shimano/sram-10 and campy-11 only. I suppose that internals of 11-speed fulcrum freehub may differ to an older 11-speed campy hub.
You can either
1. Change the freehub from shimano 10 to shimano 11
Or
2. Change to campagnolo freehub (campagnolo 10 freehub can fit campagnolo 11 cassette. The spacing is identical) and use campagnolo 11 cassette (eg chorus, record, sr) with the rest of yr your shimano 11 Groupset. For 11 spd, shimano sram and campagnolo are interchangeable (though they won't tell u so).
Sent from my SM-G920I using Tapatalk
Or
