Paris 2007 and more...
Lovely kit Jekyll man!
Oh, and hello from Disley! Where are you?
Arms of a sprinter, legs of a climber, lungs of a smoker!
I cycle, therefore I am.
http://www.dukinfieldcc.org/ http://photobucket.com/albums/b32/clpowellbikes/
- jekyll man
Sorry i'm a bit slow replying - I've been at home and not at work
Measuring from the centre of the clamp to the centre of the rails is 150mm, with an SLR this gives me the correct height of 735mm.
This unfortunately leaves me with an itchey carbon seat post, or from the other direction, a Ritchey carb!
Hope this helps you
Phil
Hope this helps you
Phil
Official cafe stop tester
- MrCurrieinahurry
- Moderator
dude what did you do with the tan sidewall tyres?? i really liked them
tikka
tikka
- jekyll man
The rear got full of cuts, then started puncturing.
If i can pick up another pair of Michelins trhen I will.
Thats the problem when you're trying to lay down 2000W of raw power when climbing in the Dolomites!!
Or more likely its cos the roads round here are shite.....
jekyll man wrote:Sorry i'm a bit slow replying - I've been at home and not at work
Hope this helps you
Phil
That's wild...I have the same post and SLR seat..and following the seatpost, my measurement from rails to center of clamp is only 135mm and I have about 2mm before I hit the lettering...am I missing something here
thanks.....mr.thi03
PS. could u email me directly a high res pic of your post area?
many thanks........ thi03@sbcglobal.net
- jekyll man
Perhaps it's to do with the original length of the post?
I'll email you some pix later
