Specialized - Tarmac SL8 - 2024 - 5.35 kg (11.8 lbs) by Le Baron Noir
idinfo68
by idinfo68
Assembly complete! Tests as soon as the opportunity arises...
Video >>> https://youtu.be/4-K1d7LovCM
With higher wheels...
Video >>> https://youtu.be/S-ZDapHhLZk
www.baron-noir.com
Specialized Aethos SUB5
Specialized Tarmac SL8 - 5.35 kgs
Specialized Tarmac SL6 - 5.16 kgs
Scott SPARK RC 900 SL SUB 8
Specialized Epic HT - 6.18 kgs
OtterSpace
by OtterSpace
Absolutely amazing build as always. Every build you post is well documented and a fine benchmark. I frequently reference your SL6 and Aethos builds as I planned my SL6 rim build.
Some minor items to consider for such a tuned top of the line build:
Silca RD hanger for better shifting and lower weight.
Shifter clamp tuning using titanium nuts and Schmolke, or SQUICCHI band clamps.
Bolt tuning the brakes and shifters
vinyl covers
mike
Resident Pro
by mike
incredible weight! superb
idinfo68
by idinfo68
OtterSpace wrote:
Tue Feb 20, 2024 12:47 am
Thanks, glad to be useful :)
Order placed today
I replaced quite a few screws with titanium
Not useful because there is no passage to hide on this frame :D
www.baron-noir.com
mike
Resident Pro
by mike
how is the silca rd hangar? it looks pretty ugly from the pics on silca's website compared to the stock hangar. is it the #105 silica hangar to buy? what was actual weight savings as silica gives a range.
mike
Resident Pro
by mike
mike wrote:
Wed Feb 21, 2024 7:13 pm
how is the silca rd hangar? it looks pretty ugly from the pics on silca's website compared to the stock hangar. i ended up buying the silca hangar anyway and there is no weight savings at all over the stock sl8 hangar plus the dura ace pivot/bolt that ul you won't use because of the direct mount
powerangah
by powerangah
I don't understand how you shaved 1.2kg, that's mind blowing! are roval wheels and dura ace cranksets that heavy? does changing to titanium bolts make that big of a difference?
idinfo68
by idinfo68
SILCA 105 = 19 grs
Specialized original + Dura-Ace cam = 21 grs
So 2 grs saved and better shifting...
www.baron-noir.com
mike
Resident Pro
by mike
idinfo68 wrote:
Fri Mar 01, 2024 3:37 pm
SILCA 105 = 19 grs
thx my scale is accurate to within 5 grams!!!!
