Tarmac SL8 5.835kg New Pics Page 3
da123
by da123
Tarmac SL8 RTP, size 54. Build list, with weights where known:
Frame / fork : S-Works Tarmac SL8, RTP, with replacement decals by Speedy Decal
Cockpit : Roval Rapide 115/380
Bartape : EXS Ultralite (25g)
Wahoo mount : MagCad
Wheelset : CRW CS4045 (1180g)
Wheelset (2) : CRW CS5060 (1290g)
Tires : [CS4045] Conti GP5000 TT TLR 25mm (210/214) / [CS5060] Conti GP5000 TT TLR 28mm (front) and S TR 25mm (rear) (240 / 254)
Tubeless valves : Muc-off
Sealant : Peaty's Bioshot 25mm per tire
Seatpost : Darimo zero degree 300mm (107g)
Saddle : Gelu E3 (54g)
Groupset : Shimano 9200 12s
Climbing / sprint shifters : DA 9200
Cassette : Dura Ace (11-30)
Chain : YBN SLA1210 rainbow slick
Crankset : THM Clavicula SE PM (320g)
Chainrings : Carbon-ti 52/36
Chainring bolts : Carbon-ti x-lock
DM Hanger : Frames and Gear rainbow slick
Ti-bolts (rainbow) on calipers, mech hangers, top cap
BB : THM Ceramic with integrated sleeve
Bottle cage : carbonworks
Pedals : Dura Ace
Rotors : Carbon-ti (160/140) with centre lock adapters
Brake pads : Shimano Ti
Hope you enjoy!
freepk
by freepk
Crazy bike :) You can swap head cap bolt :)
da123
by da123
freepk wrote:
Sat Nov 25, 2023 9:33 am
Cheers. Where did you get the bolt from? I do have a black alu one on order which I'm hoping will fit more seamlessly.
mashiehood
by mashiehood
Hi are you able to share details of the THM Ceramic with integrated sleeve - i have never seen the sleeved version
da123
by da123
mashiehood wrote:
Sat Nov 25, 2023 12:12 pm
You have to get them direct from THM. They don't sell them through the retail sites. I went round the houses a bit with other BBs that had sleeves (c-bear, ceramicspeed, WheelsMFG), but had issues with all of them (with the Clavicula crank). Then told THM that I was having problems getting the cranks to operate without play with the other BBs, and they said they could do one on special order. Works perfectly.
kode54
by kode54
Your SL8 weigh less than my 52cm RTP Aethos.
Differences:
Berk saddle
Partington wheels
Continental 5000s TR 30mm tires
Hope RX rotors
THM SE crank with no PM
Hambini BB
Darimo T2 seatpost
All stickers removed
Darimo stem
Darimo Elipse bars
Must be the tires.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
da123
by da123
kode54 wrote:
Sat Nov 25, 2023 12:49 pm
Differences:
Berk saddle
Partington wheels
Continental 509s TR 30mm tires
Hope RX rotors
Hambini BB
Darimo T2 seatpost
Darimo stem
Darimo Elipse bars
Must be the tires.
I suspect a lot is in the tires. Around 200g less for my set up I suspect, possibly more if you use a lot of sealant. Your BB will also be quite a bit heavier (THM one is circa 70g). You don't say what chainrings you use either, so maybe something there? Or maybe someone's scales are wrong 😂. Mine did weigh the same at the bike shop though, so I'm reasonably confident they are accurate.
freepk
by freepk
da123 wrote:
Sat Nov 25, 2023 11:38 am
Extralite https://r2-bike.com/Extralite-Ahead-Kappe-Hypercap_2
kode54
by kode54
Differences:
Berk saddle
Partington wheels
Hope RX rotors
Hambini BB
Darimo T2 seatpost
Darimo stem
Darimo Elipse bars
Must be the tires.
I suspect a lot is in the tires. Around 200g less for my set up I suspect, possibly more if you use a lot of sealant. Your BB will also be quite a bit heavier (THM one is circa 70g). You don't say what chainrings you use either, so maybe something there? Or maybe someone's scales are wrong Image. Mine did weigh the same at the bike shop though, so I'm reasonably confident they are accurate.
Using Carbon-Ti 52/36T rings.
Shimano group 12-speed
Direct mount hanger
30ml of sealant
30mm Conti 5000s TR (not sure what happened…auto-correct before)
I’m using a Feedback Sports hanging scale.
- Factor LS Disc
da123
by da123
freepk wrote:
Sat Nov 25, 2023 5:43 pm
Haha, that's quite interesting, as I already have that top cap, which I bought some years ago for a different build. I must therefore have that bolt somewhere - so will search it out...
da123
by da123
kode54 wrote:
Sat Nov 25, 2023 9:20 pm
Differences:
Berk saddle
Partington wheels
Hope RX rotors
Hambini BB
Darimo T2 seatpost
Darimo stem
Darimo Elipse bars
Must be the tires.
Direct mount hanger
30ml of sealant
Nothing there then. What does your Aethos weigh in at?
Aryeh
by Aryeh
Are you gonna use the Darimo drag bars for another 70-80g savings?
da123
by da123
Aryeh wrote:
Sun Nov 26, 2023 9:15 pm
I'd consider it for sure. I wonder how the Darimo bar would match up to the Rapide cockpit from an aero perspective though. I also found the Darimo handlebar I had on a different bike quite uncomfortable (in terms of vibration), so I'd probably also wonder whether their integrated bar would be similar.
kode54
by kode54
da123 wrote:
Differences:
Berk saddle
Partington wheels
Hope RX rotors
Hambini BB
Darimo T2 seatpost
Darimo stem
Darimo Elipse bars
Must be the tires.
Direct mount hanger
30ml of sealant
5.94kg
Close but at 52cm, should be less I would think.
- Factor LS Disc
kode54
by kode54
Could also be the heavier MCFK stem that I switched to since it matched the Aethos round tubes better. Haha
- Factor LS Disc
