2021 Ridley Helium SLX Disc - First Attempt at Weight Weenie
RidleyMeThis
by RidleyMeThis
Hey all! First post and first bike build/weight weenie attempt. I think it turned out way better than I even planned as it came in under the weight I thought it would be. I will attach a build sheet once I clean it up a little bit. But for now I will attach photos of the final build and first ride.
6.4kg/14.12 lbs
fa63
by fa63
Nice build, and that is a great weight. It does look like that frame might be a bit small for you, or you simply need a frame that has a much higher stack than the Helium (you are running at least 40mm of spacers, which is often the limit for forks with carbon steerer tubes, with an upturned stem).
LouisN
by LouisN
That's light with these standard parts !!
The bike would look superb with cut steerer, a -12 degree stem and minimum spacers :).
Aesthetics call for a medium (this is a small right ?).
Louis :)
asiantrick
by asiantrick
I'm 100% calling CAP on the weight. There's no way this is under 15lbs. My RIM brake Helium SLX is heavier yet more light weight parts.
CAP!!
RidleyMeThis
by RidleyMeThis
fa63 wrote:
Fri Oct 20, 2023 3:10 am
Yea, didn't expect the spacers to come out that much talking with the builder. But we decided to start higher and ride it a few times and then work to bring it down. He didn't want to cut lower until I was 110% sure. My current outdoor bike was more endurance geometry so higher stack. My trainer bike is almost a complete match to the Ridley and I have been messing with that bike to see how everything felt. I have rode 3 times and going to remove spacers and then ride again. My guess is at least half the spacer height and flipping the stem will take place.
RidleyMeThis
by RidleyMeThis
asiantrick wrote:
Wed Oct 25, 2023 2:49 pm
CAP!!
Honestly I didn't expect to get this low. I knew I'd be around 14.5-14.7 lbs but I think I lucked out on weight of the parts.
There's the shot from the builder after it was complete. He put it back on the scale when I picked it up and I saw the same number. I added the wahoo mount and a rear light mount since.
RidleyMeThis
by RidleyMeThis
LouisN wrote:
Fri Oct 20, 2023 10:02 pm
Louis :)
It's size XS. Working to reduced the amount of spacers and flip stem. Builder wanted to start higher and move down versus starting lower and not being able to add. Shouldn't be an issue for me but since my current bike was more endurance geometry I'd rather start up and bring it down.
asiantrick
by asiantrick
RidleyMeThis wrote:
Sat Oct 28, 2023 1:08 am
Louis :)
god damn, no f way.. I'm 100% shocked with the weight. What year SLX is this btw. Nice weight. Sorry for calling you out <3
MrCurrieinahurry
by MrCurrieinahurry
Tbf its this is weight weenies we need scale shots when weights are low
Basso Diamante eps 12
RidleyMeThis
by RidleyMeThis
After some testing with stem height and length I have it finalized. Lowered it and went to a -6 degree FSA stem. Looks better though I know its not fully slammed...tssk tssk me haha.
mike
Resident Pro
by mike
excellent weight and looks excellent with the lowered stem. the slx was always very light frameset
