Specialized Tarmac SL7 49cm 5.9kg
dudemanppl
by dudemanppl
Finished the build! Sub 6 kilos with a non S-Works frame, not too shabby. I don't have a hanging scale so it's honestly probably over 6kg, but I will just pretend its under 6. Been riding the first iteration of the bike with the Hunts and have been liking it a ton. Got the rims in today and built the wheels up. There really isn't any aspect I can think of upgrading, everything is maxxed out. The Prestacycle cassette shifts decently enough for me not to want to take it off.
Code: Select all
Frame		809.7		Specialized Tarmac SL7 49cm
Small Parts	59.2		RD/FD Hangers, SP Clamp, ICR Grommet, etc.
Fork		335.9		Specialized Tarmac SL7
HS		79.1		Tarmac/EXS
Expander	21.3		J&L/EXS
Cage Bolts	2.6		J&L
TA		67.2		Specialized
Total		1,375.0g
Shifters	329.7		Shimano Dura Ace Di2 R9170 Tuned
FD		102.7		Shimano Dura Ace Di2 R9150 Tuned
RD		184.3		Shimano Dura Ace Di2 R9150 Tuned
Brakeset	204.7		Magura Flat Mount Tuned
Hose		61.3		Magura Hose/Banjo Bolts
Brake Mounting	61.3		Magura QM52/Better Bolts Ti
Di2		101.6		Junctions/Wires/Battery
Chain		219.3		Shimano CN-HG901
Crankset	568.4		Quarq DUB 165mm 110mm BCD/Cannondale MK V 50/34t
BB		73.3		BBInfinite DUB Ceramic
Total		1,868.4g
Barstem		302.3		EXS Aerover 110x36
Seatpost	128.6		Hylix Cut
Saddle		95.4		Berk Lupina Padded Black 132mm
Bartape		21.2		EXS Airtape
Bottle Cages	56.4		King Ti
Total		603.9g
Wheelset	1,086.1		Light Ride 36/GOLDIX/Sapim Laser
Tires		468.4		Veloflex Corsa Evo 28mm
Tubes		48.8		Revoloop Race Ultra 40mm
Rotors		166.8		Galfer Wave Centerlock 140mm
Cassette	157.0		Prestacycle 11-27t
Total		1,927.1g
Build Total	5,774.4g	12.73lbs
Pedals		188.6		Look Keo Blade 2 Ti 16nm
Build + Pedals	5,963.0g	13.15lbs
Original post below:
After the whole Ventum fiasco, I found what was supposedly an S-Works Tarmac SL7 up on FB Marketplace for a steal of a price.
Unfortunately the seller was looking to do a local sale only and was located a 6 hour drive away. Luckily, I convinced the seller to drop it off at a local bike shop to get packaged up and sent over to me. So I patiently waited...
It arrived a few days later and I quickly got to work stripping it down so I could get rid of the eTap ASAP. There were a ton of paint chips and both the headset and bottom bracket bearings (which turned out to be BBInfinite WS2 coated! Unfortunately the lifetime replacement warranty doesn't apply for second owners :( ) were completely knackered, indicating the rough life this bike had previously. What a crazy thought that people actually ride their bikes. :? :?
Once I got down to the bare frame and fork, I put them on my scale. 851.2g for the frame? 352.8g for the fork? Goddammit. It's definitely not an S-Works. The previous owner had mentioned that it was painted by Squid bikes, who use crappy canned single stage paints from spray.bike. I went ahead and started with some paint thinner on a rag and got to work. Luckily the old finish came off relatively easily and I soon got my answer.
Just as I suspected, its a 2021 non S-Works frameset. Two positives, its the lightest colorway possible and the Squid bikes folks didn't do ANY surface prep before spraying. That meant the original finish was actually in pretty good condition. Two hours later it was completely stripped. It ended up at 809.7g for the frame and 346.8g for the fork. I also brought this fact up with the seller and he gave me a sizeable partial refund which I appreciated. If only Ventum would own up to their mistakes.
Before I recieved the frame, I was planning on getting it custom painted BMW Marina Bay Blue Metallic, but seeing that this wasn't an S-Works frame and the finish underneath was quite presentable, I held off. I spent some of the partial refund on some titanium hardware from betterbolts.com, a lightweight Prestacycle cassette, and some small parts to update the worn/missing items. Overall, I won't be missing out too much weight wise, the financial benefits definitely trump whatever few grams I'd save if it were an S-Works.
Currently waiting for a few parts to come in, but this will be the preliminary build until I get my new wheels built up. The weights with asterisks are unconfirmed (needing a few final parts to come in), using online resources (I love R2 bike), or are not the final weight (e.g. the hoses/steertube requiring cutting still). The final build with the intended wheelset and seatpost should be ~570g lighter, although the first iteration is nothing to sneeze at either.
Code: Select all
Small Parts*	58.0		RD/FD Hangers, SP Clamp, ICR Grommet, etc.
Fork*		335.0		Specialized Tarmac SL7
HS*		67.0		Tarmac/EXS
Cage Bolts	2.6		J&L
TA		67.2		Specialized
Total		1,360.8g
Hose*		95.6		Magura (Uncut)
Brake Mounting*	22.4		Ti
BB		74.0		SRAM DUB
Total		1,902.7g
Seatpost	173.3		S-Works SL7 20mm Setback 300mm
Bartape*	25.0		EXS Airtape
Total		652.4g
Wheelset	2,173.2		Hunt Aerodynamicist 44 w/ tires/sealant/valves/etc.
Tires		0.0		S-Works Turbo 2Bliss 28mm
Sealant/Valves	0.0		No Idea
Rotors		203.3		Shimano RT-MT900 160/140mm
Total		2,533.5g
Build Total	6,449.4g	14.22lbs
Build + Pedals	6,638.0g	14.63lbs
And heres a preliminary mockup. Its gonna be a spicy meatball.
iamraymond
by iamraymond
This is going to be a much better bike than that Ventum. What spider are you going to use on that crankset to get the weight to 568g? I'm guessing not a PM spider.
dudemanppl
by dudemanppl
That's the complete weight with Quarq spider and chainrings.
oldturd
by oldturd
Thank goodness no prep work on the paint! Waiting to see the final form of this spicy meatball
iamraymond
by iamraymond
dudemanppl wrote:
Thu Sep 14, 2023 3:26 pm
Those Cannondale rings must be really light. My setup weighted 618g. Quarq Dzero (125g) + SRAM Red 165mm DUB (333g) + Praxis Buzz (129g) + Bolts (31g)
robbosmans
by robbosmans
Who in their right mind would pay someone to use spray bike on their 8000$ bike lol. Luckily it came off easily. Glad you saved the fred build
LouisN
by LouisN
@robbosman think of those burglars in action movies trying to escape a bank robbery with painted stolen cars ;)...
Louis :)
dudemanppl
by dudemanppl
iamraymond wrote:
Fri Sep 15, 2023 9:43 am
Yeah they run ~103g with bolts. You should replace your bolts, alloy chainring bolts run around 10g for the set.
dudemanppl
by dudemanppl
iamraymond
by iamraymond
Huge improvement from when you got it. Did you hit the 6.6kg projected weight?
Thanks for the tip about the bolts. I just saved 20g using some alloy bolts I already had. Never realized that the ones that came with the Quarq spider were steel.
dudemanppl
by dudemanppl
Build is still in process, waiting on rims. It should be under 6.6 right now still sitting on the Hunt wheels. I don't have a hanging scale though.
dudemanppl
by dudemanppl
Building straight pull double butted round spokes is so tiring.
Nixster
by Nixster
Look good though!
What did you build?
