Building a new rim brake bike in 2023: Time Alpe d'Huez 01
simbikotic
by simbikotic
Is this an anachronistic thing to do? Oh well...
I wanted to snag a new rim brake frame as they seem to be becoming rarer and rarer :cry:. Not a retro-grouch - I love my disc bikes - but I have some good rim brake parts lying around and wanted to do a rim brake build before it's too late.
Anyway Time had a sale on ADH 01 frames, and I have always been curious about this brand and their manufacturing method. Also, the geometry is a good match for me. So here we are.
darkmother
by darkmother
Looks like you are off to a good start to me.
How do you plan to build it up?
MDecius
by MDecius
I am really looking forward to seeing this, as I just finished an ADH01 rim brake of my own, final weight was ~7.8kg with very value-conscious parts rather than weight-conscious.
This thread will be a nice source of info about how I can cut weight in the future.
One thing is for sure, you will love the ride feel & quality of this frame. Mine rides like a dream.
Road - Time Alpe d'Huez 01 rim
All-road - Diverge Elite DSW '16 disc
mike
Resident Pro
by mike
Time framesets are flawless and amazing to ride
simbikotic
by simbikotic
Note, here are the weights of all the small bits I removed from the frame before weighing. There were a couple of bits of hardware that were hard to remove, namely the front mech hanger (riveted - sorry 1x fans) and also a bearing race in the head-tube. But, 955g is the closest I could get to a bare-frame measurement.
simbikotic
by simbikotic
Also, some closeups of frame parts. The forged dropouts look lovely. The bb-shell face looks a bit rough on one-side, but otherwise fairly clean.
simbikotic
by simbikotic
Thanks for the comments everyone! I am not sure how 'weightweenie' the intitial build is going to be. I am planning to pull Campag Chorus 12 sp and Campag Zonda wheels from a donor bike to get her rolling and look at upgrades later. I do have a Deda superlegerra RS handlebar and an S-Works power saddle lined up, which should help a bit with the grams.
Main concern right now is finding time - work is very busy - so it may be slow build.
MDecius
by MDecius
simbikotic wrote:
Tue May 16, 2023 5:17 am
You should be able to get it to a quite reasonable weight with 12 speed Chorus imo. Before I planned my build, I debated over and over with myself about going for 12 speed Record, which would have been quite a bit lighter than what I ended up with, Ultegra Di2.
Looking forward to following this thread!
DHG01
by DHG01
Love this frame; one in a while I look into eBay and alike hoping to find a good deal.
simbikotic
by simbikotic
Finally got around to doing some building...
Fitting the Chorus mechanical I opted to cross the wires for smoother bends and no paint contact. It was a bit of a faff to make sure the crossed wires in the downtube were not touching.
First time I have worked with an internal wire-guide in the bottom bracket. I was a little worried that the wires seemed to be touching the carbon:
But, when under the tension of the mech-spring they lifted up by about a mm and cleared the carbon.
simbikotic
by simbikotic
Pressing in the BB cups was interesting. This is the first frame I have owned with a press-fit BB. I was searching online for a press-fit tool that was not extremely expensive, when I started to wonder: is it crazy to press ithem in with a bench vise...? After thinking on it for a long time I decided that there were some pros (the vise keeps things nice and square) and cons (the vise can exhert a lot of force, quickly). I decided to mitigate this by placing sheets of stiff-yet-brittle acrylic between the cups and the vise:
The theory being these provide a nice flat face, prevent the vise jaws from marring the cup/frame and will break easily alerting me if I apply exess force.
Anyway, it worked quite well and the cups pressed in very smoothly:
I feel a bit bad about it, because I generally like to use the "right tool for the job". But it seemed to work flawlessley and saved be some $$$.
simbikotic
by simbikotic
And the finished build....
simbikotic
by simbikotic
Oh, and of course the weight. I am actually really happy with the final weight given that it is not the lightest frame and I am using alloy wheels and a 3rd level groupset. It's plenty stiff and light enough to be fun on the hills. Off for a ride...
killerrabbit
by killerrabbit
Awesome! Love the build. I keep an eye out for these in rim as well
keaton
by keaton
very nice, i dig!
