Winspace SLC 2.0 w/ Campagnolo 12 - 7.26kg
My frame arrived today! Excited. Instantly took it out the box and weighed it.
Packaging was really impressive and undamaged. Frame and forks look incredible.
Size 490 rim brake (superlight) black colour:
Frame 800g on the nose
Hanger 14g
Uncut fork 402g
Seatpost 190g
Seatpost clamp 19g
Headset bearings and dustcap 68g
Steerer tube plug and top cap 55g
I'll probably do a similar post to this once it's built up with Sram red 10 speed and other aliexpress bits and bobs.
Cheers!
Hanger 14g
Uncut fork 402g
Seatpost 190g
Seatpost clamp 19g
Cheers!
Timony wrote: ↑Thu Dec 29, 2022 3:09 pmMy frame arrived today! Excited. Instantly took it out the box and weighed it.
Hanger 14g
Uncut fork 402g
Seatpost 190g
Seatpost clamp 19g
Cheers!
Please, could you take some pictures and post it ?
[/quote]
Sure, attached some pics below.
I cut the fork today and now weighs 368grams. Frame is rim brake so I'm guessing that will be lighter than a naked disc frame. Also worth mentioning the rear hanger is 14gs and frame is fully internally cable routed with the slick white outers - which adds a tiny bit of weight. I also weighed the frame with the front hanger because I'm planning on going 2x.
Currently building it up and waiting for a few bits to arrive in the mail - I'll post more pics once it's built up.
Thanks!
[/quote]
Thanks!
Looking forward to your finished build
Question on your 490 frame....
Do you normally ride a 53/54cm then?
Looking at their sizing is a bit confusing & I was curious myself
Thanks
Almost finished now, just got to wait for the farsports before I start indexing and getting rid of links in the chain.
Yes, I do usually ride a 53/54.
I'm roughly 5ft10, usually ride a medium giant tcr. I've been riding it for years but always found the head tube to be slightly too long/high, probably because of the 'overdrive' steerer tube - however, the reach was ok(ish, maybe a little bit too long). The effective top tube on the winspace is probably quite similar to the giant which has longer top tube but shorter seat tube.
Judging from the geometry on the winspace site, it seemed to have slightly shorter top and head tube which brought the stack down, reach was slightly decreased as well. We'll see how it goes once I start riding it haha.
- Attachments
- geo.PNG (29.44 KiB) Viewed 3034 times
Can't seem to add the horizontal photos I took.
Firstly, build weighs just under 5.9kg which I'm really happy about. Haven't taken it out because it's been quite icy around here.
Secondly, building it up was very simple even with my basic mechanical skills. I did have a few problems with the internal cabling.
- The rear brake internal cable exit (not sure what it's called but it's where the cable exits the frame) kept popping out so I've stuck it down with ugly electrical tape. You can't really tell from a distance as the tape is black - bit of an inconvenience.
- Another internal cable issue I had is I'm using Jagwire shift cabling and the cable end didn't fit flush with the cable exit on the frame (near the rear derailleur), there's only about 1mm of space and wobbles around a tiny bit. May not be an issue with other cable brands.
Thanks, if it becomes an issue then may look into that.
I was going to try increasing the length of the outer cable to the rear brake, it has enough slack already though.
Thanks.
Wow! Nice build.Timony wrote: ↑Tue Jan 24, 2023 2:12 pmCan't seem to add the horizontal photos I took.
Have you already tested the bike?
What can you say about the frame? Is it stiff? Is it confortable? How does it work on the flat, climbing and descending?
I'm trouble about the size, your frame is 490, which is you saddle hight?
Thank you very much.
Thanks! I will hopefully be riding on the weekend if there is no ice on the roads. I'd hate to slip over on the first rideRone69 wrote: ↑Wed Jan 25, 2023 6:11 amWow! Nice build.Timony wrote: ↑Tue Jan 24, 2023 2:12 pmCan't seem to add the horizontal photos I took.
There is not much flat around where I live. Only up or down.
Saddle height depends on a few things - I'm using 165 cranks, dura ace 7900 pedals for reference. The centre of pedal to centre of the saddle is 87.25mm (leg inseam is roughly 80mm). I think I will take a set of allen keys with me when I go ride it to improve the fit.
Timony wrote: ↑Wed Jan 25, 2023 11:02 pmThanks! I will hopefully be riding on the weekend if there is no ice on the roads. I'd hate to slip over on the first rideRone69 wrote: ↑Wed Jan 25, 2023 6:11 amWow! Nice build.Timony wrote: ↑Tue Jan 24, 2023 2:12 pmCan't seem to add the horizontal photos I took.
Sorry but I don't understand, How many millimeters are there between the center of the BB and the center of the saddle (A)?
In my bike A=725mm, crank=172.5, reach 390, stack 540 (+ 25mm of spacers), I think that the 520 can fit well for me, 490 size maybe is too short and need to many spacers under the stem.
- Attachments
- IMG_20230121_173523326_HDR.jpg (99.47 KiB) Viewed 2641 times
Sorry, I should have made that clearer. 'A' measurement is 715mm.Rone69 wrote: ↑Thu Jan 26, 2023 6:27 amTimony wrote: ↑Wed Jan 25, 2023 11:02 pmThanks! I will hopefully be riding on the weekend if there is no ice on the roads. I'd hate to slip over on the first rideRone69 wrote: ↑Wed Jan 25, 2023 6:11 amWow! Nice build.Timony wrote: ↑Tue Jan 24, 2023 2:12 pmCan't seem to add the horizontal photos I took.
I'm by no means a bike fitter but my giant had roughly the same reach and stack as your current setup. I would get in contact with winspace and send them your stack and reach, see what they would advise.
I sized down for weight, that was my main reason to be honest - I have a 100mm stem and 110mm stem (both cheap uno) just in case. I've added 15mm of spacers to the steerer but I think I will eventually go to 5mm spacer. I've ridden this on the rollers this week and feels like I could go lower.
Timony wrote: ↑Thu Jan 26, 2023 9:56 pmSorry, I should have made that clearer. 'A' measurement is 715mm.Rone69 wrote: ↑Thu Jan 26, 2023 6:27 amTimony wrote: ↑Wed Jan 25, 2023 11:02 pmThanks! I will hopefully be riding on the weekend if there is no ice on the roads. I'd hate to slip over on the first rideRone69 wrote: ↑Wed Jan 25, 2023 6:11 am
Wow! Nice build.
I look forward to your review
Hi Timony, do you have any update? Any ride on the roads?Timony wrote: ↑Wed Jan 25, 2023 11:02 pmThanks! I will hopefully be riding on the weekend if there is no ice on the roads. I'd hate to slip over on the first rideRone69 wrote: ↑Wed Jan 25, 2023 6:11 amWow! Nice build.Timony wrote: ↑Tue Jan 24, 2023 2:12 pmCan't seem to add the horizontal photos I took.
