SuperSix Nano Black Inc. - sub 4kg ?
RouarierDmer
by RouarierDmer
This is a very rare Cannondale SuperSix Evo Hi-mod Nano Black Inc. from 2013 in size 54cm (gosh that's a long name). It took me two years to finally find one in the correct size. The original seller wanted to keep it for him, though at the same time considering to sell it to me. After several months trying to convince him, he finally sold it to a friend of his. I insisted to get his contact, and fortunately he lives nearby my place and has a passion for his numerous SuperSix'es, among others. Wasn't a cheap deal for sure, but here it is.
It is more of a long term project as I am already working on another SuperSix, but this one is meant to become a hill climb specialist, maybe sub 4kg, who knows...
Tune Golden Rocket - 5.66kg | viewtopic.php?f=10&t=161531
Cannondale Supersix HM Tri - 4.63kg | viewtopic.php?f=10&t=161698
mike
Resident Pro
by mike
It is possible but you will need to pull out all the resources to get this under 4kg
rollinslow
by rollinslow
that's a testament to determination right there. Glad to hear you got the frame, and looking forward to the build! Sub-4kg is what this needs, as well as a massive cash infusion to get it there :)
Moots Vamoots RSL (2019)-Super Record 12
Cervelo S1 (2010)-Super Record 12
Kestrel RT700 (2008)-Dura Ace 9000
Mosaic GT-1 (2020)-SRAM Red viewtopic.php?f=10&t=174523
mike
Resident Pro
by mike
The crankset is heavy compared to clavicula se so you will need to save a lot everywhere else.
RouarierDmer
by RouarierDmer
mike wrote:
Mon Jun 22, 2020 12:49 pm
Haha you are totally right mike. Therefore I am not planning to use the sisl2 crankset from the picture. Thm is the (only) way to go I believe...
RouarierDmer
by RouarierDmer
ome rodriguez wrote:
Mon Jun 22, 2020 12:45 pm
My friend's size 48.
678g is crazy light! Even though it is also a very tiny frame in 48cm...
RouarierDmer
by RouarierDmer
Finally managed to extract the bearings from the frame... Previous owner most likely had a creaking issue with the BB30, as the bearings were glued to the BB sleeve using red loctite. The BBT-90 extraction tool was not enough to get the job done, nor the rubber mallet which absorbs too much energy. So I gave it a chance with the heatgun on the bearings for a few seconds to break the bond, and then it all went out smoothly using BBT-30 tool 8)
Frame weight is 775g (nowhere near the 655g claimed by the manufacturer's marketing department, but it was probably without paint and/or a smaller size). It is still 126g lighter than my 2015 Himod frame same size, which has a heavier paint job. And no nanocarbon technology :wink:
RouarierDmer
by RouarierDmer
Rather than the fancy nanocarbon technology and a lighter paintjob, I think most of the weight difference between a normal Himod and the Nano comes from the Bottom Bracket sleeve: one is a big chunk of metal, the other is a very thin aluminum sleeve with big holes in it.
mike
Resident Pro
by mike
will you be able to use clavicula se on this frame?
RouarierDmer
by RouarierDmer
mike wrote:
Mon Jun 22, 2020 1:54 pm
Do you see any reason why not? 4ibanez installed one on the same frame I believe.
ome rodriguez
by ome rodriguez
just a reference, my ax-lightness vial evo frame with headset and bottom bracket bearings is 750g, without those should be sub 700g.
mike
Resident Pro
by mike
if it has been done before then great!!!! i know in the past it took some creativity to fit non sisl bb30 cranks into a cannondale frameset
RouarierDmer
by RouarierDmer
Mon Jun 22, 2020 2:51 pm
Brutal! I love your build thread :thumbup: Is your AX vial is a size S? The only details on weight I could find are: "Weight without accessories (+/- 5%): S - 680g, M - 730g, L - 760g, XL - 785g."
RouarierDmer
by RouarierDmer
mike wrote:
Mon Jun 22, 2020 4:02 pm
Ok, well noted then! Thanks, I will crosscheck the information then.
