Slammed Stems Show!
Swannie
by Swannie
dddavid wrote:Image
black paint on the top of the top tube and head tube ruin the look (:
Nevermind that black paint.. What the f*** is that pump for?? :shock:
PARTIZAN
by PARTIZAN
My Kualis , ok Silver 5mm spacer [emoji16]ImageImage
Gesendet von iPhone mit Tapatalk
Broady
by Broady
My Brian Rourke:
cjpshawe
by cjpshawe
Image My Allez, it has -4deg shim with a -17deg stem.
Sent from my HTC One_M8 using Tapatalk
Dalzhel
by Dalzhel
No negative stem...
ImageDSC06344
jbaillie
by jbaillie
Problem with the CK NoThreadSet is that even with the stem directly atop the headset it still doesn't look all that aggressive.
e30matt
by e30matt
Not the best of pictures but...
CAAD12
Trek Madone
Cannondale Supersix Hi Mod 2015
Trek Madone 2014
Cannondale Caad12 2016
Cannondale Hooligan 2015
Cannondale Supersix evo HiMod Black INC disc
prebsy
by prebsy
if it ain't negative it ain't slammed. Unfortunately my -20* deda pista still isn't quite low enough.
Fabianinduplo
by Fabianinduplo
Attached my current assortment of slammed stems. Good pictures are not really my thing...
Apart from the Kocmo Cross Bike (5mm spacer) all are completely slammed.
Edited the King3 picture...
De Rosa King 3 RS
De Rosa Protos
Colnago Extreme Power (CK No Threadset doesn't look slammed even if it is...)
Bianchi 928 SL
Time ZXRS
De Rosa Titanio Singlespeed
Kocmo Cross Disc
tbrix
by tbrix
Fabianinduplo, what an outrageously gorgeous collection of bikes. The Bianchi and Extreme Power are my favourites.
Here's my slammage:
Bassoslam
BMCslam
anquetil
by anquetil
Im I blind or cant see slammed stems.
tbrix
by tbrix
Are you referring to mine? If so:
BMC has the stem sitting on the headset cap. That's not a 5mm spacer under the stem, that's the shape of the cap. Basso is not technically slammed as it has 3 5mm spacers under the stem. But given the super aggressive design of the head tube, the bottom edge of the stem being in line with the top edge of the top tube, and that the cockpit position of this bike is lower than my BMC, perhaps I can be forgiven?
dacrazy1
by dacrazy1
Slammed down my S5
jbaillie
by jbaillie
@dacrazy1 an S5 with Enve 7.8's and Di2... are you Mark Cavendish?
