Pinarello Dogma 65.1 think 2 - Weight saving?
Tyres, tubes, bars, stem, seat post, segmented housing. Otherwise, cranks, brakes and a little could be saved on the seat.
Sent from my SM-P350 using Tapatalk
You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer.
-- Frank Zappa
-- Frank Zappa
DURA Crank maybe
Kman that is a lot of parts, but do you know some cheap parts with low weight?
Okay... Take a pic of the serial number under the rim tape, the front hub, the rear hub, and the brake track. They're sooo obviously fake. If I'm wrong I'll send an apology.
dudemanppl wrote:Okay... Take a pic of the serial number under the rim tape, the front hub, the rear hub, and the brake track. They're sooo obviously fake. If I'm wrong I'll send an apology.
He's got nothing to prove to you so stop being a douchebag and trying to ruin other people's threads!
Other than you stem and bar what else are you willing to change? I would swap the group to D/A just to match the high-end frame better. Other than that I would leave it alone.
thanks for your replies.. I will order a dura crankset and some EEBrakes. Ti spindles for the look blade pedals, and open corsa evo tires / latex tubes.
A dogma is that heavy, and zipp 404 clinchers are too Dogma uses a special seatpost, so i can't switch that one
Lightweight wheels will make my bike weigh 6.9kg.
Okay, I will look at Birk
