Isaac Boson - Updated. Pictures on page 3
- Frankie - B
- Admin - In the industry
The saetpost clamp is 31.8 and luckily i found a KCNC clamp in black at a shop. That saved me some 10 grams. The idea that a seat clamp bolt could be alloy never realy came in my head. It stikes me as madness, but if the folks over at KCNC chose to spec it, it has to work.
The wheels for this bike will be my Roues Artisanales by Adrien. And i hope to see some Reynolds assault clinchers on the horizon. The hubs in the wheels that Adrien made for me were about 5 years in use and never have had their bearings replaced. I've done that and documented every step. I'll post about thst soon.
The complete weight of the bike is a bit over 6.9 i'm struggling to find the last few grams without giving up my alloy handlebar.
Buildlist to follow soon!
Tape is for wrapping gifts to your girlfriend, not to hold a freaking tire on!
If you want to see 'meh' content of me and my bike you can follow my life in pictures here!'Tape was made to wrap your GF's gifts, NOT hold a freakin tire on.'
- Frankie - B
And a sideshot of the bike.
The seat post clamp is replaced by a KCNC one. The tires will be swapped to skin walls before the weekend
- btompkins0112
Looking good, Frankie! It will look even better with the Reynolds!
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
- Frankie - B
Thanks for the positive comments guys!
The reason that I still ride with the old red shifters is quite easy; the other parts were due for replacement earlier, or I found a deal I couldn't pass on them. The shifters still work and I'm still on the ancient 10 speed.
The bike weights 6.75 kilo's as it stands, but without Garmin. All the bolts on the frame have been replaced with either Alloy or Ti versions. Even the bolts that hold the cable guides in place.
Can't wait to get my hands on a set of Reynolds wheels.
- Frankie - B
And a shot of the finished build:
Build List:
Frame: Isaac Boson
Fork: Isaaac
Heaset: Isaac
Headset spacers: Isaac Cone spacer and two 1cm CF spacers
Seat post clamp: KCNC
All bolts that hold the cable entries, should hold the DI2 batt and the front der hanger are replaced with either Ti or Al.
Bottle cages: Tune Wassertrager uni
Stem: 3T ARX LTD 120mm
Bar: 3T Rotundo Pro 42 cm
Seatpost: AX Lightness Deadalus Uni
Seat: AX Lightness Endurance
Shifters: Sram red first gen with BTP shifter clamps
Crankset: Sram red compact with Specialites TA inner ring in 39
Left crank: Sram Rival with Stages PM
Front Derailleur: Sram red Yaw
Rear Derailleur: Sram red
Chain: Campagnolo Record 11
Cassette: Sram X-glide 11-23
Pedals: Speedplay with custom Ti axles
Brakes: Sram red
Hubs:
Tune Mig 70
Tune Mag 180
Skewers: Tune DC 14
Spokes: DT Swiss Competition and Aerolite
Rims: Kin Lin 240 and 270
Tubes: Challenge latex
Tires: Vittoria open Corsa SC 25mm
Cables: Jagwire segmented housing.
Build List:
Frame: Isaac Boson
Fork: Isaaac
Heaset: Isaac
Brakes: Sram red
Hubs:
Tune Mig 70
Tune Mag 180
Skewers: Tune DC 14
- Stolichnaya
Bravo, Frankie!
Elegantly understated and purpose built.
Adrien's wheels are a very nice touch.
verry nice compleet build.
The reason I would change the stem and crankset is because we are weightweenies.
Most carbon stems incl this one are heavier than the aluminun ones and also the crankset is not one of the lightest.
Tarmac SL2
Epic 2009
Epic 2009
Very nice bike Frankie. I really like the overall lines of the frame.
