Basso Diamante 2015 silver/red
Beautiful bike! Well done.
You seem to have good photographic skills - it could be nice to see a side shot without all the reflections in the frame.
Donic wrote:Beautiful bike! Well done.
Thanks! I've tried it several times. It's not an easy job. Until now I wasn't able to take one without reflections.
deek wrote:Basso Diamante stem, although I'm not sure how you get it without buying the whole bike.
you can order it from Basso directly http://shop.bassobikes.com/en-UK/stem-b ... -copia.php
Michel wrote:Thanks! I've tried it several times. It's not an easy job. Until now I wasn't able to take one without reflections.
Yeah, it can be really tricky with reflections. Maybe if you try a cloudy day and work with layers - underexposing one of them ...
Donic wrote:Michel wrote:Thanks! I've tried it several times. It's not an easy job. Until now I wasn't able to take one without reflections.
I've tried it already while cloudy, sunny, direct light, etc. But I did not try to underexpose individual layers. I'll try it out, thanks!
You're welcome. I'm looking forward to seeing the result
- wheelsONfire
Krull wrote:haha, 3t and deda, made in italy? great joke!
i willingly consider using a bar with the best-fitting ergonomics. as the case maybe, it is not made in the, äähm.., italian department of taiwan.
+1
Bikes:
Open *UP* (2016.04.14)
Michel wrote:deek wrote:Basso Diamante stem, although I'm not sure how you get it without buying the whole bike.
I really like the stem as well and bought it directly from Basso. However, it will be tricky to fit it on a standard headset as it is made for the Basso set specifically. Also, it is quite wide and incredibly heavy. If I had a Basso I would use only this stem regardeless of the weight. For any other bike I believe there are other / better options
How about shortening the handlebar drops by 2-3cm? I'm using the Zipp SL bars on all my bikes and found that the flat section in the drops is just too long. Shortening it also improves aesthetics a lot.
- vejnemojnen
kgt wrote:That' why one should take Tour tests with a grain of salt.
Or they just also take into consideration the category of the given frame?
Ie.: the corones was against other budget-low cost alloy bikes, and the 2.5 score for the frameset is calculated against its competitors, whereas the Diamante&Protoss were both regarded as top-notch race crabonfibre frames.
I really luw this build, the H'bars match pretty well with the style of the frame&low setup.
please have a
I've been trying to get a hold of one of these frames for a while! Simply stunning stunning pieces of kit!!!
BASSO SORT OUT DISTRIBUTION IN THE UK!!!!
thebucket wrote:Hi Michel i'm considering buying the diamante but i'm unsure in terms of Frame size (58 or 61) Your framesize is 58.? can you share your inseam length and height? I have a 91/193cm measurement of inseam length/height.
Hi, my inseam length is 87, height ist 188. I'm currently using 1cm spacer below the stem.
cheers Michel
