Epic refresh in '23 or '24
req110
by req110
I am an early adopter on most of the cycling technologies, but i don't know to be honest.
This will surely add 300g or so.
Example rule "500 Watt = Lock mode" wouldn't work for me, because sometimes i produce 500W over the roots section.
This all seems to me similar like syncro shift - i am not using it at all.
SW SL8 RTP 56cm @ 9270 / CLX II / CS OSPW / CEMA BB
S Epic 8 L @ XX T-Type / Berg Ratheberg 30 / Quarq / Fox Transfer SL 100mm / 3p
forgottenOne
by forgottenOne
Is that custom tuned to epic, or is it just off the shelf upgrade kit?
What was the price range for the kit?
[/quote]
I guess for the epic its custom tuned. I ride another brand so i ordered the just off the shelf upgrade kit. About pricing. I don't know. They can preorder it but can't see prices at the moment. Someone told me this weekend the retail price is arround 4000$. But to be honest, i guess it will be somewhere around 3000$. I guess we need to wait till they'll launch the product.
forgottenOne
by forgottenOne
req110 wrote:
Mon Mar 04, 2024 12:56 pm
Don't you think that the system will detect that you're pushing 500W over roots? A Sensor can certainly be used to recognize wether you are going flat, up or down.
qwertzuiop
by qwertzuiop
do you need a SRAM cranks or can this shaft-looking-sensor be placed in any crank that has space?
jbattermann
by jbattermann
The original FA's spindle sensor was made for dub cranks specifically & I would be very surprised if anything but the new T-Type/Transmission cranksets will be supported / the sensor made to fit snug into those
HHH
by HHH
Minirac
by Minirac
FA needs transmission crankset, cadance senzor and power meter. So FA only on whole S works bike seems logic.. 15k?
Snabb
by Snabb
Ride lots!
req110
by req110
Frame: "optimized for wireless drivetrain and seatpost" is worrying me. I am planning to use a cable actuated seatpost. (i have ordered sworks frameset). Any insights on that? I hope it will be possible.
UPDATE: guy on another forum told me that cable routing will be done the same way as on epic wc.
req110
by req110
req110
by req110
Seems like flight attendant
- fork gains 119g
- shock gains 131g
- sensor 99g
thats 349g.
sram remote twistloc is 79g, plus few grams for housing.
Minirac
by Minirac
500g over World cup.
vboy19
by vboy19
does anyone know if there are spacers that are wide enough for the the gap between the roval integrated stem and the top tub? looks so wierd with the tiny spacers that specialize provides
req110
by req110
No sir.
vboy19
by vboy19
Also what I find interesting is that the fork on the epic is using the ultimate lowers?? When you look at the pros they are using flight attendant with the SL lowers with the cut out.
I was thinking about buying the frame set without flight attendant and then sell the ultimate fork buy the sl fork then upgrade to flight attendant so I can have the lighter fork.
