2022 new xc frames?
Hexsense
by Hexsense
Snabb wrote:
Tue Aug 15, 2023 8:53 am
The supercaliber frame weight isn´t that light compared to other frames that has 100-120 mm. So with a good lock-out what is the benefit of the supercaliber and Epic WC bikes ? I like the design but not sure if I should change my Epic yet.
Epic WC rear suspension is definitely different from the rest.
It use little to no negative volume. It sag at 0-5% rather than 25-30%.
Normally negative travel before sag point is there to track the undulating terrain to smooth things out, provide better tire grip and stability.
Make it sag at 0% means it's pretty much a hardtail with blow off travel reserve only for large hits. It doesn't provide traction benefit of normal suspension design. But it is brutally efficient like hardtail without the need of lockout.
SuperCaliber is just short travel bike. It doesn't function the same way as Epic WC. So in the case of SuperCaliber. I agree. I'd pick Epic Evo over SuperCaliber.
Snabb
by Snabb
Hexsense wrote:
Tue Mar 05, 2024 10:05 pm
I have a Epic with Brain because I like the 0 % sag feeling for racing. Maybe I should test the Epic WC. The WC riders seems to choose the evo for racing though...
Ride lots!
zscs
by zscs
zscs wrote:
Mon Mar 04, 2024 8:45 pm
Didn't want to create a new topic; here is an interesting new frame from the German Bike Ahead Components: "The Frame". https://r2-bike.com/BIKE-AHEAD-COMPOSIT ... -UD-Carbon
Although BB is Pressfit, but quite a few positive things (to me at least):
- 30.9mm seat tube inner diameter
- brake hose lining is internal but NOT goes over the headset bearing :)
- 2 bottle cages (I know, that's the minimum nowadays)
- PM brake mount (I truly hate flat mount on my Lux CFR...)
- UDH
- I believe geometry is a good compromise between modern and classic (68.5°)
- lovely classic design
- 2k EUR for a 880g frame is... Maybe on the pricy side but at least made in Portugal.
Size L, 4 bolts included + 2 rubber plugs:
UDH hanger is 24g, Intend collar 10g, 12mm axle is 44g. Really nice frame - maybe I'll post the details of my planned, (partly) oldschool build based on this with 1x11 mechanical shifting. ;)
req110
by req110
zscs wrote:
Mon Mar 18, 2024 7:51 pm
- UDH
Inform us more, post more pictures of whole build. I consider this frameset too. Is headset bearings included or do you have to purchase aftermarket? Thank you.
SW SL8 RTP 56cm @ 9270 / CLX II / CS OSPW / CEMA BB
S Epic 8 L @ XX T-Type / Berg Ratheberg 30 / Quarq / Fox Transfer SL 100mm / 3p
bikewithnoname
by bikewithnoname
New Yeti ASR has been released for those of you with a turquoise disposition 115 RR 120FR
Bielas
by Bielas
"PM brake mount (I truly hate flat mount on my Lux CFR...)"
What is to hate the Flat Mount? With a flat-mount caliper it's easy to adjust as in a road bike. If using an adapter for a PM caliper it adjusts just like an original PM brake...
Flat mount makes lots of sense for hardtails or rear triangles without dropout pivots, because the frame can be full carbon without molded threads inside and more simple shape
:mrgreen:
JayDee81
by JayDee81
Bielas wrote:
Wed Mar 20, 2024 4:08 am
You are very limited with brake choice because only lightweight brakes are made with Flat mount. You basically get mtb lever and road caliper... And of course the brake is weaker then.
zscs
by zscs
req110 wrote:
Mon Mar 18, 2024 8:54 pm
Headset is not included.
Fortunately, I had a spare Cane Creek AER 52/40 IS from a few years ago (does this A.E.R. thing still exist / in production?:)) and bought a relatively cheap, but very light PRO SL - IS 42/28.6 upper part for this build. Sure, I'll share some more info in a dedicated topic! ;)
@Bielas: I have a bad experience with my SRAM flat mount caliper. The weak braking performance only a thing (more or less, I can live with it), but I have to check and adjust it in every 2-3 rides, somehow the screws get loose, even with Loctite 243 and tighening them with torque wrench. An another issue is, there's a shortage on flat mount calipers. Last year I wanted to install my MY2018 Trickstuff Piccola brakes and waiting for C22 flat mounts almost for a year and still not is stock / not available. A few months ago I decided to buy a Magura MT8 flat mount caliper instead of the very pricey C22 and I got the Magura one with a wrong bleed screw. Now I'm trying to live with the SRAM one came with my Lux CFR...
Okay, installing a new brake pad is not a flat mount issue, but pushing the pistons back into the calipers in my case is a PITA. I had to buy this tool, otherwise the disc contacts the new brake pads, because there's no enough free space between the disc and brake pads.
req110
by req110
I don't see a problem with flat mount bikes, you can simply buy fm/pm adapter and run post mount brakes.
hannawald
by hannawald
According to some reviews Supercaliber is totally efficient bike, you almost don´t need the lockout except for start sprinting but it is more comfortable than Epic WC at the same time. See Flowmountainbike review for example. Supercaliber looks to be a better option out of these two. Epic WC is purely for racing and even the racers don´t ride it.
Hexsense
by Hexsense
My post don't mention anything about ride review.
Just how suspension works according to leverage curve, anti squat and positive to negative air volume.
Supercaliber get traction and comfort of full suspension bike with sag. Just with shorter travel.
Epic WC work as hardtail with blow off. Because it sit at top out (no sag) due to its shock having almost no negative air volume.
They are different. Which approach is better depend on who you ask and what you are looking for. Obviously, tester who prefer full suspension feeling will like SuperCal more because SuperCal still function like most other full sus, just with shorter travel. Epic WC is uniquely different.
hannawald
by hannawald
Hexsense wrote:
Fri Mar 22, 2024 9:15 pm
:beerchug:
I just wanted to add that there is some ride quality in Supercaliber, it´s not just a heavier FS bike with lack of rear suspension travel but it is a bike with unique isostrut suspension which gives the bike very efficient feeling. You don´t need to work with 3 position lockouts etc.
aeroskii
by aeroskii
Snabb wrote:
Thu Mar 07, 2024 10:32 am
The evo is lightest and has a lockout. Also 120mm of travel
Aeo
by Aeo
zscs wrote:
Fri Mar 22, 2024 2:50 pm
They are available here https://www.bikedoc-shop.com/en/p/trick ... ineral-oil
Giant TCR Adv Pro Disc '17 · BH Lynx Race Evo '19 · Seraph GR029 '21 · Canyon Inflite AL '14
