$500...What crank arm set?
2ndgen
by 2ndgen
I'm thinking my CAAD is deserving of a different set of crank arms.
I'd love to get a Hollowgram set as that seems like the proper thing
to do, but it's a non-BB30 frame so I'm looking for another option.
I'd like to be able to keep the Dura-Ace 7800 BB & Praxis 53/39 Chainrings.
Of course, the main reason for possibly getting out of the Ultegra SL crank
would be for significant weight savings. I've calculated the entire set-up to come
in at 773g (rings, bolts, BB, crank). A Dura-Ace 7800 crank is out of the question.
Oh, and it HAS TO BE Black (carbon would be nice as well).
So, since I can't slap on a Hollowgram, what are my options if I decide to go all the way with my drivetrain?
2002SaecoReplica
by 2002SaecoReplica
7900 crankset
or
Rotor 3D+ with BSA30 adapter.
/thread
- Zipp rims will break if you look at them too hard
- R-Sys wheels will spontaneously explode
- The ZG crankset will never, ever exist
- Everyone needs Lightweights, even if they're fat and old
- Parts actually made of metal are SO 10 years ago
Kastrup
by Kastrup
What about the Rotor 3D without the +?
"Stay cool and try to survive" A. Klier to the other members of the Garmin classics squad the night before P-R.
Rippin
by Rippin
Lighter, carbon and $500 and under:
Red Black crankset, then strip the graphics?
____o
_`\<,_
Bling
by Bling
KCNC K-Type looks great. I just got one and it comes in at 620g with the BB and rings.
_____________________________
I'm handsome
Briscoelab
by Briscoelab
A 7900 crankset would look great on your bike. Keep the DA rings on there though.
Getter
by Getter
I'd go with the 24mm spindle 3D. I highly doubt that you'll be able to tell the differences vs the 3D+.
Looks-wise, if you run Shimano cranks you have to run the Shimano rings...or else it just won't look right. The Praxis rings at first glance look just like the rings off a SRAM Red crank. If you run the Rotor...it won't look so obvious.
justkeepedaling
by justkeepedaling
Dura Ace 7900
Gearjunkie
by Gearjunkie
Bling, good weight for your KCNC.
Is it standard or compact and what length?
2ndgen
by 2ndgen
Thanks for all the replies.
DA7900 won't garner me much of a benefit as it's barely a 48g loss.
I think there'll be compatibility issues as well right?
(will have to go with a 7900 chain? cassette?)
I'll keep reading & researching. Thanks. :thumbup:
Hopefully, one day, someone will actually make a non-BB30 adapter for a Hollowgram.
aaric
by aaric
2ndgen wrote:Thanks for all the replies.
No compatibility issues. No chain or cassette replacements needed (other than considerations if your existing cassette/chain have a lot of wear that you'd have with any new set of rings)
Also, you'll lose 48g, but gain a lot of stiffness. Conventional wisdom is that to gain much weight off of a DA7900 crank, you'll give up a ton more stiffness and shifting quality, which is why you are getting a ton of recommendations for the 7900.
prendrefeu
by prendrefeu
2ndgen wrote:Hopefully, one day, someone will actually make a non-BB30 adapter for a Hollowgram.
It would require a custom spindle as well, as the lengths & location of bearings will be different. The diameter of the spindle isn't an issue however, just the length.
shoopdawoop
by shoopdawoop
Perhaps save up a little more and get a power meter? If not my vote goes to a Rotor.
2002SaecoReplica
by 2002SaecoReplica
They already do, it's called Rotor 3d+ with BSA30 adapter.
davej35
by davej35
DA 7900 is exactly good choice if you're looking for a combination of lightweight and durability.
