Let's See Your Time Trial bike
glam2deaf
by glam2deaf
If we're posting front on shots:
I've got some work to do. The blipbox is obnoxious.
dereksmalls
by dereksmalls
Stoo wrote:
Wed Jul 04, 2018 12:07 am
How are you allowed to race with your bars on that angle? Wasn't that position banned after like 2006 or something?
glam2deaf
by glam2deaf
Stoo from memory doesn't race UCI events so has freedom there. Nate just rides to the cafe and back so he's good. And for me I'm working in the +/- 10 cm rule that the UCI has. Though there isn't an official clarification as to where that is measured from. With a flat pad it's easy, b ut throwing them on an angle changes everything.
Stoo
by Stoo
As glam2def has said, i race very few UCI races and if I do, I have a few options.
Leave the pads where they are and run 30deg reverses extensions and the shorter single button di2 switches
Or
Use the same 40deg extensions and shorter di2 switches and move the pads forwards and higher up the wedge.
This leaves my hands and elbows in almost the same place but the pad would be on my forearm not elbow.
Measurement is taken from the mid point of the pad.
'18 Giant Trinity Pro TT - DA9070 - QuarQ DZero - HED Jet 9+/JET+ Disc3
'18 Giant TCR Advanced Pro 1 - R8000 - QuarQ DZero - SLR1
'16 Genesis Equilibrium - U6800 - FSA SRM - WH6800
'13 Giant Trinity Composite - U6870 - QuarQ DZero
nathanong87
Resident master of GIF
by nathanong87
Honestly... given the situation, no.
You’ve made the best of what you can there.
My only suggestion may be a set of one piece, ‘mono’ arm rests like mine.
That way you ‘may’ be able to hide the blip box behind it for a cleaner flow by having the blip box top mounted over the top of the extensions (as opposed to it effectively being under mounted at present)
mono arm rest looks very tidy, i get what you are saying, i think i'd need to print another blip mount to move it higher.
Anyone living in Russia can help me out source a part? [7/2/19]
Nate ★ Life , my tumblr joint
Instagramz
Stoo
by Stoo
It would be the same mount but with the blip mount on the other side of where it is currently.
nathanong87
by nathanong87
i've always wondered about the mono pad in the way that it functions for riders. Is it under the assumption that the fixed width, i assume is narrow as possible, is best aerodynamically for the majority of riders?
looks like it weighs less for sure (if that's a consideration) and perhaps it being one piece creates less turbulence in that area than two pieces?
Instagramz
Stoo
by Stoo
I don’t know about any aero benefits/drawbacks but it’s narrow and stiff (braces the stack)
nathanong87
by nathanong87
CrankAddictsRich wrote:
Thu Jul 05, 2018 4:23 pm
I don't have a head-on shot.... this is the closest I've got.
not a response to your post, but in general, i wonder when a new shiv will release. Must be winning the award for longest time since last update amongst any brands?
Stoo wrote:
Thu Jul 05, 2018 4:16 pm
stoo have you done anything custom to the front end of the trinity? are the cables on the standard module naturally hidden like you have it? are those stack riser spacers (not the angle ones) standard or you made those?
Instagramz
CrankAddictsRich
by CrankAddictsRich
nathanong87 wrote:
Thu Jul 05, 2018 4:45 pm
Totally agree... I've been saying that for at least the last two seasons. I thought for sure there would be a new one for the TDF, but it doesn't look like that will be the case, maybe for the WC's?
Stoo
by Stoo
nathanong87 wrote:stoo have you done anything custom to the front end of the trinity? are the cables on the standard module naturally hidden like you have it? are those stack riser spacers (not the angle ones) standard or you made those?
Nothing custom aside from the angled wedges/armrests/extensions.
Stack risers are all standard, I just used electrical tape to cover the gap between the pillars of risers.
It seems the UCI are clamping down even further on TT position measurements.
- Elbow rests must be made up of two parts (one part for each arm) and are only allowed if extensions are added ;
- The maximum width of each elbow rest is 12.5cm ;
- The maximum length of each elbow rest is 12.5cm ;
- The maximum inclination of each elbow rest (measured on the support surface of the arm) is 15 degrees ;
- The maximum dimension of the cross section of each extension is 4cm ;
- The height difference between the elbow support point (midpoint of the elbow rest) and the highest or lowest point of the extension (including accessory) must be less than 10cm.
So my mono arm rest will be illegal regardless of whether or not I move the extension tips within spec!
tmr5555
by tmr5555
when your budget implodes yet you want marginal gains and like DIY tinkering.
Homemade Disk Wheel cover, Wilier Cento 10 Air TT mode.
15th in turkish nationals.
Anyone fancy counting how many UCI Rules I broke with this rig? LOLZ
nathanong87
by nathanong87
Stoo wrote:
Fri Jul 06, 2018 8:44 am
dear UCI, stop hatin
..... wonder how this affects the team sky printed setups
Instagramz
by Nefarious86
See no sky, speak no sky?
Sent from my SM-N950F using Tapatalk
Using Tapatalk
