Slickest saddlebag alternative, components and weights
Zitter
by Zitter
or you can get this for 1/5 the price
http://www.lezyne.com/organizers#panel-7
i usually use two of them, one for phone, wallet, keys and another for repair kit, but I just got the Arundel saddle bag so I only need one now.
fordred
by fordred
I use the continental saddle bag which is just big enough for a tube and 2 levers.
viewtopic.php?f=14&t=59409
twoangstroms
by twoangstroms
Re: organizers for carrying in jersey pockets
I've had pretty good luck with plastic bags and a few rubber bands. Those keep stuff organized, clean, dry, and can be used as structural elements in case of emergency. And free with fruit and/or veg.
RichTheRoadie
Tinker, Taylor, Tart
by RichTheRoadie
Most stylish = Rapha Seat Pack
Most compact = Arundel Uno
When I run clinchers I use an Uno - it's so small it's barely visible. On a long ride I'll run the Rapha seat pack so I can carry 2 tubes and a better multi-tool. Whatever ride I'm doing I also have a Rapha Essentials Case to carry a few other bits.
FWIW, I've also been able to roll up a pre-glued 22mm Schwalbe Milano tubular to fit in the Rapha Seat Pack without too much effort, which makes it no bigger than if I were running a large saddle bag (and MUCH smaller than the Arundel tubular bag).
JTKK
by JTKK
Rich-Ti wrote:Most stylish = Rapha Seat Pack
Thanks for the good info Rich.
Do you have any pics of the Rapha Seat Pack installed with tubular?
twoangstroms
by twoangstroms
Yes, good info.
One question, though. As someone posted above, some small saddlebags are functionally wide enough, either the bag or the Velcro straps, to brush against inside thighs when riding. My small Specialized bag ate through a pair of shorts that way before I noticed. How is the Arundel or others in that respect?
RichTheRoadie
by RichTheRoadie
JTKK wrote:Do you have any pics of the Rapha Seat Pack installed with tubular?
I'll try and sort some this week.
RichTheRoadie
by RichTheRoadie
Here we go then - pre-glued Schwalbe Milano 22c tyre rolled, taped and then rolled up into a Rapha Seat Pack:
RichTheRoadie
by RichTheRoadie
Oh, and this bit...
SL58
by SL58
Powerful Pete
Location: Lima, Peru and the Washington DC area - it's complicated.
by Powerful Pete
The microfiber "holdy bag" looks like a well made alternative to the ugly [and heavy] plastic bottle holder thingie I have in my parts bin...
Supercommuter: Jamis Renegade...
Oldie but goodie: De Rosa Professional Slx, Campagnolo C-Record...
JTKK
by JTKK
Thanks BikeTart for posting pics of Rapha seat pack. Is there still room for a multitool and few C02 cartridges?
I also have Komm-Vor+ saddle and also Schwalbe milano spare tubular so that is pretty good option then. Does it stay under the saddle so it does not ruin the shorts?
RichTheRoadie
by RichTheRoadie
There's still room for a multi-tool and CO2, but it'll obviously make the rolled up pack bigger.
You'd need to be careful on the orientation and placement of the pack to avoid your shorts rubbing, but it's no bigger than a large saddle bag when the tub is rolled up like that. I actually think it will go in lots of smaller saddle bags like that too.
I was only trying the Rapha Seat Pack as an experiment - I'm actually using a Lezyne pouch in my jersey pocket and the tub, CO2 inflator, 2 CO2 canisters, lip balm, multi-tool and money also fit quite comfortably.
fpmesiIII
by fpmesiIII
all you need is a
and a jersey pocket...
bones
by bones
SL58 wrote:Check out some Ratio designs:
http://www.ratiobikedesign.com/website/ ... Itemid=478" onclick="window.open(this.href);return false;
Good find. These guys have some cool stuff!
