The wheelbuilding thread
WinterRider
by WinterRider
What I most appreciate around this discussion forum is the civility. Exchanging viewpoints.. opinions and learning is my goal. And I've learned some things.........
The for-mentioned & pictured 18-10 I've built was re-laced NDS this morning.. heads in vs the heads out experiment first time around. Due to the wide elbow's of the Sapim Strong spokes I lost around 9+ kgf tension on the left.. but I believe by subjective testing the wheel is laterally stiffer. NDS tension is 70% of DS's 117 av kgf now.
Originally... laying this wheel on the padded table and applying pressure to the rim with care -- I rated it less stiff than a 32 H rear laced normally. The latter no inflated tire.. the 18-10 with tire mounted to 100 psi. Yet after repeating this admittedly very subjective test.. I am not sure. Suffice to say.. I do not believe the difference is large... if any. I think mounting a tire on the 32H and checking them both in dropouts with firm thumb pressure might be worth a trial. Riding them obviously the ideal.. but snow/salt season does not see my better components used.
Litespeed Appalachian 61 cm
Litespeed Blue Ridge 61cm
Miyata 210 25"
eric
by eric
KLabs- I'll trust a well designed actual experiment over a theory. Rinard is Cervelo's lead engineer and was Trek's. If you think his experiment gave incorrect results, why don't you try to replicate it? You can find pics of his test rig chucking a wheel into a milling machine if you search for them. Or you could do it with an old steel frame laid across a couple saw horses, and a dial indicator (but then there's some flex from the frame to consider).
I don't have much of an opinion of triplet lacing because I have not tried it myself. What little I know from reading and talking to Troy Watson, an experienced wheel builder who built a lot of triplet laced wheels, about it is that it works best with a hub designed for it, one that has a very wide NDS flange spacing. The only aftermarket hub I know that was designed for triplet were the ones designed by Troy a few years back. They're no longer made and I don't remember the maker.
bm0p700f
by bm0p700f
Eric has given the reason why I do not se triplet lacing.
KLabs
by KLabs
eric wrote: ... If you think his experiment gave incorrect results, why don't you try to replicate it?
Hi eric, as have I posted earlier, it is the method not the results that I consider incorrect.. The results appear to be correct for a Static test.
As described the method used is a Static test and I believe that the method needs to be a Dynamic test, which of course is quite difficult to setup.
I believe that the spoke tension/detension cycle needs to be included in the test (which results from rim and hub flex due to lateral, radial, and torque forces) which means the testing method needs to be Dynamic..
A spoke tension/detension cycle will not occur during a Static test, especially not as it occurs while riding
The maths I have posted, at least for me, allows me to determine how laterally stiff any wheel build that I do will be ... so for me that is sufficient ( and I have shared it ... ) :)
I prefer to work with some form of maths and SpokeCalc does not provide me with enough information.. The process was still a little too touchy/feely for me ... :)
I will now have a look at a formula for effective Torsional stiffness (Effective Torque Control) ... this process is still a little too touchy/feely for me ... :)
Re triplet lacing, I agree completely that it works best with a hub designed specifically for it (such as wide FTF spacing, etc), but that is also the case with traditional 12-12, 14-14,16-16 arrangements, and for any arrangement.. The best hub for a particular arrangement must always be determined (mathematically) and we do not always have the privilege to use the best hub ( or do we ) ... thanks KL :)
kavitator
by kavitator
will this be a problem for tubular? (too long spoke)
WinterRider
by WinterRider
eric wrote: The only aftermarket hub I know that was designed for triplet were the ones designed by Troy a few years back. They're no longer made and I don't remember the maker.
Hi Eric,
Can you remember if Troy's NDS hole drilling was conventional or a pattern specific to his hub? Goggled for it and can't find anything.
Ah the lateral stiffness can of worms.. a complex topic. Riding wheels to the limit is still the only real world method to compare them per stiffness.
If I was into testing wheels for stiffness.. which I am not.. I'd run this simple test. Lay the wheel on it's side.. onto something rigid like a truck rim. Load the wheel at the axle with weight and measure defection downward. Do both sides. Some computer type should be able to figure how much weight is the same effect as an elite rider powering a wheel to the max.
Miyata 210 25"
WinterRider
by WinterRider
http://youtu.be/c7RJpf_KQo4
Here's some wheel testing.........
Miyata 210 25"
KLabs
by KLabs
Hi WinterRider, nice machine and now that's closer, especially as the testing is being done with the tyre and tube fitted :)
I wonder how well it is mimicking Torque effects and it still doesn't flip flop like a sprinter/climber but closer ... really nice find WinterRider :)
leejdavies
by leejdavies
Zen Cyclery wrote:@leejdavies-I wouldn't recommend the radial lacing on the NDS of that build. I've done that before with a 340/T11 combo, and I had problems with the non drive side going slack. I think that a 2x NDS would be far more practical. For the front wheel, a radial build would be just fine. Keep in mind that front wheels are usually much stiffer than rears because they have even relative tensions, where as rear wheels have a significant tension offset. For the hole count, you won't notice any difference between 20h and 24h. On the rear though I think you should overbuild a tad and go with a 28 hole, at least.
Thanks for the tips Zen Cyclery. I don't think I'm too heavy on wheels, only broke 1 spoke in my cycling life but would rather have a ~30g heavier wheel over a broken one miles from home. :D
Denavelo
by Denavelo
Has anyone ever heard of a rim having the mending section inside of the rim come loose? I recently purchased a set of Tune 70/170 hubs that were built by Fairwheel Bikes and the front Stans 340 rim has a weird noise internally. If you take the tire off of the rim and deflate and shake the rim in your hand back and forth you don't hear anything. If you mount a tire and inflate to 110psi, you can hear a noise exactly at the rim joint section. I took it to my LBS and they suspect when the rim was built, some rims have little pieces of the weld internally. Maybe that piece has come loose? There's no way to get it out of the rim and the sound is ridiculous when riding. I'm going to warranty it back to Stans, but just wanted to see if this is common with other rim manufactures.
I can post a youtube video later with the noise. Almost like the metal inside is sliding back and forth. I would love to see what's actually making the noise inside the rim.
Speedvagen Road Machine "2011 Surprise me | Rob English "Mudfoot" 29er | Focus Izalco Max
eric
by eric
I have had a couple Mavic Open Pros with that.
Are Stans welded? Most rims are pinned these days.
Denavelo
by Denavelo
so I called Stans and it's a simple fix. The joint/weld/mending section has a small plate that's help by glue apparently.
All you have to do is remove a spoke and drop some Mastik in there and it holds the plate back in place. No more noise!
xis
by xis
Hi, mates!
I'm a new member here. First of all, I wanna thank everybody for the information available, that helps a lot!!!
English is not my mother language. Hope you all understand what I need.
I intend to build a wheel set using the components below "with a little help from my friends" from Weight Weenies. :beerchug: (Beatles... =-] LoL!)
BITEX RAR9 REAR HUB
BITEX RAF10 FRONT HUB
MAC-AERO 424 CN SPOKES
GENERIC ALUMINUM NIPPLES
KINLIN XR-200 RIM 20H - FRONT
KINLIN XR-200 RIM 24H - REAR
Questions:
1) What type o lacing do you recommend? I was thinking in "radial" for the front wheel and "1 cross" for the rear wheel. What do you suggest?
2) What is the advantage of 1, 2, 3 or 4 cross when building a wheel?
3) How do I calculate the spoke length?
4) Anyone here that have these same Bitex hubs and Kinlin XR-200 rims could send the measurements necessary to calculate the spoke length?
I have these images from the Bitex website:
Information about me: My body mass is only 60 kg and my height is 1.72 m. Yes, I'm skinny! I think this wheel set can take me everywhere without effort! LoL!
I'm just a beginner (two years of cycling only), but one day I hope to contribute like you guys do. =)
Dear moderator, in case of this thread is not published in the right place, please move it. Thanks!
xis
by xis
More information:
RAR9 REAR HUB SPECIFICATION :
Weight : 191g
Rolling System : Sealed Bearings / 4
Gauge : 14
Spoke Holes : 24H, 8/16H.
O.L.D : 130mm
Axle : Ø10 - A7075
P.C.D : Ø38.5 / 49.6
Casstte : Aluminum
Pawls : 6
RAF10 FRONT HUB SPECIFICATION :
Weight : 66g
Gauge : 14
Spoke Holes : 16 / 20
O.L.D : 100mm
Axle : M9 - A7075
P.C.D : Ø30
Flat Spoke
Wookieopolis
by Wookieopolis
We have a little thread about wheel building going on in the "Everything Wheels" sub forum: viewtopic.php?f=113&t=74564 You'll find more good information than you can probably handle there.
