Time VXR Shimano Di2 tuned internal wiring - WW project bike
coloclimber
by coloclimber
Life started as this- 970 grams of hand crafted, lugged carbon, Pro Tour goodness from France
A few hours of wet sanding and it turned to this- 905 grams of gorgeous spun carbon weave
Unscrewed the cable stops-
Enlarged the hole a little-
A few choice parts-
A few modified parts
A few stock parts
A few parts to be modified
More to come...
-Deacon Doctor Colorado Slim
dgasmd
by dgasmd
You are going to be very happy with the ride of a TIME bike. It is something I cannot describe, but I think I found the bike I will be riding for a long time when I put together my TIME.
Mads Kock
by Mads Kock
Duuuude - seriously... STOP!!!! :mrgreen: :mrgreen:
Ladeira
by Ladeira
Mads Kock wrote:Duuuude - seriously... STOP!!!! :mrgreen: :mrgreen:
PLEASE DONT :D
bomber
by bomber
I have been looking foward to this build since the hints started... CC you are such a tease :thumbup:
Friends don't let friends ride Mavic... or Pinarellos!
My ex ride
My old rides
tonytourist
by tonytourist
I've been wanting to see more pictures of this, looking forward to your progress on it 8)
exhibitx
by exhibitx
wow this is a serious build, looking forward to seeing the rest
strobbekoen
by strobbekoen
wow Nathan,
that's pretty cool.
Koen
majklnajt
by majklnajt
Colo, you are a carbon WW component bitch!!! :thumbup:
mrfish
by mrfish
I'm surprised there was already a hole - I would have expected glue only.
Have you thought about adding a reinforcing patch over the enlarged holes? 3 layers at 60 degrees each would help, and look something like a Parlee bottle cage fixing. I would hate to see a crack starting there. Personally I would have gone down the route of cutting the wiring harness to allow threading, or perhaps using alternative connectors rather than enlarging the holes to take connectors. I like soldering though ;-) Also I'd recommend getting some bulkhead grommets (car supply shop) so that you get a waterproof install.
+1 that this is a great project. Keep up the good work!
coloclimber
by coloclimber
Thanks for the support guys. My wife is working in the evenings and this project gives me some good time in the garage when the kids are asleep. :mrgreen:
mrfish- I like the reinforcement idea a lot.
The Di2 internal wiring kit comes with grommets but I prefer the re-inforced solution and making it more permanent and waterproof.
The bosses are screwed on with a small standard flat head but were also glued/painted -so it took a little more elbow grease to get them off. The screws holding the bosses together were connected by a rod all the way through the frame. The actual hole once the boss was off was tiny.
Schmolke bars are in thanks to lancejohnson
TheBurnOut
by TheBurnOut
What are you doing for wheels?
coloclimber
by coloclimber
The wheels arent decided yet. Its really bugging me.
The bike is for 4 gran fondos this summer. I want sexy, stiff, light and very aero wheels. I want to keep them under 45mm and under 1200 grams.
Gran Fondo Boulder, April 11, 2010- 65 miles 4800 ft climbing
Gran Fondo Vail, June 19, 2010- 80 miles 5500 ft climbing
Gran Fondo Centurion Cycling, Boulder (CO), July18, 2010- 100 miles 10000 ft climbing
Gran Fondo Steamboat, August, 15, 2010- 110 miles 5500 ft climbing
Here is my running list of possibilities:
Dura Ace 7850 28mm/24mm (-heavy and not very aero, + free, since I already have them)
Easton SL 38mm (-not sexy or light, + free, since I already have them)
Custom Edge 45mm or AX 42mm (- very expensive, + sexy, light and rebuildable, dial in stiffness and weight)
LW Ventoux (-not aero, not stiff, not rebuildable, very expensive, + sexy and light)
Zipp 303 45mm (-not sexy, + aero )
Mavic Cosmic Carbone Ultimate 40mm (-expensive and relatively heavy, + stiff and sexy)
Thoughts?
strobbekoen
by strobbekoen
Nathan,
You might consider a custom built wheelset with corima winium rims for climbing. You can easily build it into a 1100g wheelset. I know you probably can't get the rims there but well.. you know me :wink:
