Scott fork
arinowner
by arinowner
I recently bought a Scott Addict R4. Upon further inspection I noticed that there are 2 cracks around the dropouts on the fork. So instead of getting an OEM fork, I want to try the aftermarket. However I do know nor can I find the rake measurement for the Addict fork. I am looking at a Ritchey WCS fork. It's being sold in 2 versions. A 43mm or a 45mm. It would be nice to know if I can get the correct rake.
If anyone knows if the Addict fork is a 43mm or 45mm or whatever it is, could you let me know please?
1 cross thread is better than 2 lock washers
dukey
by dukey
Funny, I have a similar problem, I bought a used R2 but the steerer is a bit short. Have you verified if the crown-axle is the same as the original fork as well?
arinowner
by arinowner
Crap...I knew I forgot something. It's still at the shop. I'll check monday.
Doolop
by Doolop
Skip the WCS, go for an edge composites.
mythical
by mythical
Scott Addict forks are a bit tricky. They're about 1cm taller crown-to-axle. Put a shorter fork in and it'll totally mess up the geometry.
“I always find it amazing that a material can actually sell a product when it’s really the engineering that creates and dictates how well that material will behave or perform.” — Chuck Teixeira
RideWert.com
Wert Cycling on Facebook
arinowner
by arinowner
Ok. I measured my fork from middle of the dropout to crown in a straight line and got 380mm. Now I have to find that measurement on a Ritchey WCS...
merkyworks
by merkyworks
just an FYI if you are the original owner and have a proof of purchase you can go to a Scott dealer and Scott will warranty the fork for the cosmetic crack in the paint. i have seen this issue with some of the forks that are painted and not bare carbon. paint doesn't want to flex like the carbon does and so it cracks but the carbon under is still ok and not damaged.
arinowner
by arinowner
I thought about that. This could be tricky. The bike was bought by a sponsor of a well known racing team here in the US. The bike was crashed and the top tube was cracked. A very small crack mind you but still a crack. The handlebars swung around and hit the top tube from the side. I don't know if the frame was replaced by a frame replacemeny policy or what but all I know is the frame and fork had been sitting up at my favorite bike shop all summer long. After I took pictures of the crack on the top tube and sent them to Calfee, who said it could easily be fixed, did I ask to buy the frameset. I picked it up for almost free. It was a cash deal. Then I found the cracks in the fork. Still, I think I made a good deal. I happen to know the director of the team and will ask him the details of the frame when he gets back into town. Maybe I can persuade him to help me out.
Just a note.... I did find out that the Addict fork is proprietary. I will have to purchase another Addict fork if everything falls through with the original owner. Findiing out what the rake is on the original fork is now a mute point.....
SEQUIPA
by SEQUIPA
So what the rake after all?
43 or 45?
sharkman
by sharkman
Do yourself a favour and get yourself a original fork. Tried a lot of forks in the addict but nothing beat the original that makes a perfect match with the frame. I know they are expensive but i think I might be able to help you out since I have a few spares (all depending on the steerer length you need, drop me a pm.)
jmilliron
by jmilliron
And they are light.
sricardo
by sricardo
Hi, Now I have some problem. My fork broken and I can't find other R4. could someone help me? Do you know the size? or one other brand I can use in replace? thanks a lot
bones
by bones
mythical wrote:Scott Addict forks are a bit tricky. They're about 1cm taller crown-to-axle. Put a shorter fork in and it'll totally mess up the geometry.
What is the axle-to-crown height on the Scott Addict fork?
