tune SpeedNeedle seatpost compatibility list
dlight
by dlight
M2racer seatpost can filed but only the lower clamps not the upper clamps which is made of something harder (maybe ti). I'm not sure if it can be file.
morrisond
by morrisond
Doesn't work with a Bontrager Triple X- Lite post, this is a side clamp. Anyone know if it works with an FSA K-Force Lite?
eddd
by eddd
Sorry about posting this in two sections.
Any more seatposts we can add to either the list of posts that work or do not work?
eddd
yoko
by yoko
LP Composites seatpost is compatible with Tune Speedneedle.
cadence90
by cadence90
tune Speedneedle Alcantara with Extralite The Post UL (240mm for road).
"Gimondi è un eroe umano, che viene sconfitto ma che continua la sua corsa fino a tornare a vincere." - Enrico Ruggeri
pablo
by pablo
And is compatible with a seatpost Woodman :?:
Florian
Site Admin
by Florian
pablo wrote:And is compatible with a seatpost Woodman :?:
Which of the various models do you mean?
Image Image
noiz
by noiz
Seatposts compatible with TUNE Speedneedle:
  • Control Tech RP Carbon Comp
  • Easton EC 70
  • Extralite (all posts)
  • LP Composites posts
  • New Ultimate
  • Thomson seatpost
  • tune Starkes Stück
  • USE Alien with OS head (only after modification)
  • Ritchey WCS Carbon
  • FSA SLK carbon
Seatposts NOT compatible with TUNE Speedneedle:
  • Bontrager Race XXX Lite
  • Easton CT2
  • M2Racer (could work with a bit of filing)
  • Moots Straight Laced and Laid Back
  • Race Face XY
  • USE Alien
If your post is not listed above and you want to find out if it's compatible, post it in this thread.
SpeedNeedle users who are running posts other than the above are encouraged to contribute their seatpost compatibility experiences, either positive or negative.
The listings above will be updated with your input.[/quote]
mattpage
by mattpage
Does anyone know if its compatible with the Easton EC90 CNT (2005 model)?
eddd
by eddd
I have been in touch with Albert Bold from Bold Precision and he is planning on making a clamp that would work with the SpeedNeedle. I sent him my saddle so he could work on it. He said it would be a couple of months before he can re-engineer his existing clamp. I will update when I get anything new.
I have also been told that the AX Europa works but have not tried it personally.
eddd
eddd
by eddd
Does anyone have first hand exsperience with both the Ax & Schmolke posts. What are the advantages/disadvatages of each posts copared to each other.
Thanks
eddd
Pedä
by Pedä
compatible:
schmolke carbon sl
schmolke carbon tlo
ritchey wcs/ pro/ comp alloy/ carbon versions
frm carbon seatpost (do not know the exactly name)
truvativ team
trigon carbon (bicycles store germany)
Pedä
HOWMUCHDOESITWEIGH?
by HOWMUCHDOESITWEIGH?
eddd wrote:Does anyone have first hand exsperience with both the Ax & Schmolke posts. What are the advantages/disadvatages of each posts copared to each other.
Thanks
eddd
I have a Schmolke post and have absolutely no complaints about it, but I recently purchased an M2Racer post... 27.2 x 280mm @ 98 grams... a similar design and feels just as comfortable for alot less money... If I were to recommend a post, it would be the M2Racer... great value for a superlight post...
BILL NIKO, YOU WILL NOT EVER BE FORGOTTEN.
*adrenalin*
by *adrenalin*
it´s also compatible with
# heylight hsp II superlight
(you need some modifications!) - but: now heylight offers custom made clamps for speedneedles!
weight: 162 gr. in 290 mm
oliver
-----__o
---_\ <,
--(_)/(_)
Adri
by Adri
Hilset Titanium post
Shimano XTR post
Kore Lite post
all work with Speedneedle
Auribus teneo lupum
