tune SpeedNeedle seatpost compatibility list
robotec
by robotec
Any information if the tune speedneedle fits a syntace P6 carbon seatpost?
I have purchased a red spedneedle that looks beautiful an weighs in at 94 grams. I am still struggling with the 34,9mm seatpost to select.
Thanks
Hi|ikus
by Hi|ikus
My P6 is pretty darn similar to a Thomson in terms of the seat clamp, so I think you'd be safe.
Shut up legs and do what I tell you!
Dennis Iturriaga
by Dennis Iturriaga
I have one question:
Is the Speedneedle compatible with:
KCNC SC Pro Lite
Thanks for your informations!
Dennis
gram
by gram
It should work just fine with the KCNC post. I have used it with a Syncros post and a Easton EC70, which has a clamp much like the KCNC SC Pro Lite.
I recommend using the KCNC Ti Pro Lite, best bang for the buck seat post. Works fine with the Speedneedle, really bites down good on those fat rails.
FYI, currently Tune is not exporting the Speedneedle to the US. I stopped using mine cause it gave me some nerve damage. After a few months of use I had numbness and pain in one leg, if I replaced the seat the issue would go away after several weeks. I am using the Selle Italia TT Flight, I gained 67 grams but I least I can ride without the nerve issues. (166 g vs 99 g)
Peace.
Gram - Ibis Mojo
www.gramslightbikes.com
1043limitedgrams
by 1043limitedgrams
I used syntace P6 with my speedneedle,
not sure if your ment to thought :)
bobbyjoe
by bobbyjoe
Campagnolo record 08 seatpost compatability?
nile8866
by nile8866
How about LOOK 595/586 integrated seatpost???
Anyone tried?
Thanx in advance!
adgem1
by adgem1
Is the Tune speedleneedle compatible with the Ritchey stubby seat post ?
Scott spark LTD,Kinesis -crosslight PRO 5,kinesis evo,TK,Orbea alma,Canyon Ultimate cf
cool120
by cool120
Tune speedneedle with a 11mm diameter compatible with new Ritchey Superlogic seatpost (1-bold) ?
Ritchey SideBinder 1-bolt is for a 7mm diameter....
breeze
by breeze
Hi,
is the actual (2009) Speedneedle compatibel with the Giant ISP Seatposts, especially with the Advanced SL ISP?
Martin.F
by Martin.F
Not a question about speedneedle, but the concorde saddle also made by tune. Will it fit the ritchey carbon wcs 2-bolt?
Juho K
by Juho K
I have Speedneedle on my Ritchey WCS carbon 2-bolt seatpost, and works out great.
On my roadbike, the original seatpost was Specialized carbon which has similiar 1-bolt design as Ritchey 1 bolt seatposts. Problem was that the seatpost only accepted round rails, and Speedneedle has oval rails. So if I would've tried to put the speedneedle on 1-bolt seatpost, I would've ruined those so precious carbon rails.
Martin.F
by Martin.F
I have the speedneedle and 2 wcs posts. So if I was interested, I would easily find that out ;) What I was wondering about was if the tune concorde / becker concorde /carbon-ti concorde /frm blackhole will fit the ritchey wcs 2bolt post.
GuNKiLLaH
by GuNKiLLaH
Guys I just installed the Speedneedle on the starkes stuck and the seatpost marked the carbon rails of the speedneedle, is this regular? :?:
I don't think so because I can even see some of the YELLOW fibers coming out of the rails!!! I'm pretty scaried about this.
Here's the pic after the first real ride.
There are two marks where the rails are sitting in this picture (after today's rides) and two marks that were done when I first installed the saddle and tested it on the block around the bikeshop. I've used the torque wrench on both instalations.
THANK YOU GUYS!
MY YOUTUBE Channel - Helmet Cams, Notubes Working, XC Riding in Brazil.
My 9.050g Epic S-Works with custom paintjob & my CX bike
GuNKiLLaH
by GuNKiLLaH
None? :noidea:
