KCookie
by KCookie
dgasmd wrote:
Wed Apr 17, 2019 3:09 pm
KCookie wrote:Darimo UD Matte 40cm, 3 pre drilled holes.
Very happy with the weight. 136.6g.Image
Sent from my SM-G960F using Tapatalk
Simply insane!!! Very nicely done!!
Many thanks, can't wait to get them installed.
Johnny Rad
by Johnny Rad
Specialized Prevail ii, sz L, 267g
I don't care for the straps that don't lay against the side of my face. You know, for the Rules plus they vibrate at speed if the tension gets just right. If I recall correctly, I had the same opinion of the original Prevail years ago. I admit to a wee bit of buyer's remorse on this one...
** Previously wore a Kask Protone, sz L, 283g - nice enough, but not enough cooling in summer
*** Previously to that wore Catlike Mixino, sz L, 285g - may have been noiser than the Protone
**** Previously to that wore orig Specialized Prevail, sz L, ???g - same issue with the straps as the Prevail ii, If I recall correctly
bilwit
by bilwit
ryanw wrote:
Wed Apr 17, 2019 7:44 pm
I bought it as an entire unit, stem and faceplate / mount.
The 110mm stem is quoted at 83g, so I would assume the mount weighs 12.9g without the faceplate mounts (95.9g - 83g = 12.9g).
Came like this:
got a pic of it installed w/ the headunit? been thinking about getting a couple of these but they kind of look messy, also might be too long for my Bolt
ryanw
by ryanw
The mount supplied is absolute garbage. Snapped off and Garmin 1030 on the deck due to this.
Have replaced with a better, more secure mount.
'16 Cervelo S5 - 6,650g RIP
'17 Focus Mares Force 1 - 7,170g
'19 Cervelo S5 Disc - 7,460g
IG: RhinosWorkshop - Check it out for all my custom builds :thumbup:
:!: Ride Southern Spain Cycling Holidays *£445 for 7 Nights* :!:
nickf
by nickf
I'm willing to bet they could have made this thing with just one center carbon arm. Seems over built just to hold a cycling computer.
Klaster_1
by Klaster_1
nickf wrote:
Tue Apr 30, 2019 12:28 pm
Maybe it was designed to handle heavier devices. A lightweight computer and light should be possible.
Sergio from Extralite wrote:CH-01 fits well the Garmin 1030 (125g / dimensions 59x114mm) and should hold over twice that weight.
dgasmd
by dgasmd
1. Bought myself a Retül bike fitting session. So many numbers to tell me a lot I already knew and make small adjustments, which I guess means my guestimations weren’t that far off. The adjustment of my cleats may be worth it’s weight in gold if it proves to be good long term. We will see......
2. Portable A/C for the garage where I ride the trainer during the weekdays. Getting hot in there even with the door open and a huge fan!!
thedanplasse
by thedanplasse
I just ordered an Extralite 120mm -6 stem claimed 87g
It should be in within a week or two. Hopefully that'll compliment the Superergo bars I'll be getting next.
2018 Specialized Tarmac Expert Sl5
ND4SPD
by ND4SPD
More gear:
I was in dilemma between Gaerne G.STILO and Giro Empire SLX, Gaerne are a little more comfortable, and it seems to me they are made a little better...
Gaerne G.STILO 2019
http://www.gaerne.com/cycling/en/artico ... ilo/black/
I wanted red ones:
But they didn't had them, so I bought black ones:
And some more things:
Camelbak Podium Ice
https://international.camelbak.com/en/b ... 86821ab040
MB Wear socks
https://wearmb.com/en/51-bike-socks
Giro socks
https://www.giro.com/en/men/mens-bike/m ... ries-socks
Vredestein Race Tube 60 mm
https://www.bike24.com/p276405.html
Topeak Aero Wedge Pack Large
https://www.topeak.com/global/en/produc ... wedge-pack
sennder
by sennder
I got from Starbike:
  1. 3T Superergo LTD 40cm bars to replace my Bontrager XXX VR-C bars. Huge upgrade in terms of comfort, especially on the tops and on the corners before the hoods. Internal cable routing for mechanical + rim brake setup was easier than expected.
  2. Continental GP5000 28mm non-TL tire to replace my worn GP4000SII 25mm rear tire. Still to mount it.
I do not have a scale so can't weigh either.
--Sennder
ND4SPD wrote:
Tue Apr 30, 2019 6:18 pm
More gear:
No doubt about this. Gaerne are better quality shoes than any model from Giro.
robertbb
by robertbb
kgt wrote:
Wed May 01, 2019 6:31 pm
More gear:
This is a really big call. Got anything to back it up?
TobinHatesYou
by TobinHatesYou
robertbb wrote:
Thu May 02, 2019 3:14 am
More gear:
It's a big claim, but it's true for the most part. I own shoes from both brands. I wear my Giros primarily because they fit my feet slightly better, but there's no doubt in my mind the Gaernes are made to a better standard with better materials. Gaerne shoes are handmade in Italy down the street from Sidi and AlpineStars. They all know how to make beefy shoes that will take a beating on a motorcycle. Gaerne does not care about making lightweight shoes. They don't use glue where metal fasteners should be used instead. Their micro-tex feels a lot more like leather than what Giro uses. My Giros have had minor issues with longevity. The heel lugs on my Prolight Techlace fell off. The carbon sole on my Empire SLX started to separate from the upper around my pinky toe.
Imaking20
by Imaking20
Current:
Acid Minty
Boone
Retired:
Wilier Wonka|The Dentist|The Bucket List|Specialissima|Evo|T2|Blue|Project C6.0 | elt AR FRD|Colnago C59|S-Works Tarmac SL4|S-Works Venge| Wilier Cento1 SL|Tarmac SL2
by Nefarious86
ryanw wrote:The mount supplied is absolute garbage. Snapped off and Garmin 1030 on the deck due to this.
Which mount snapped?
Sent from my SM-G975F using Tapatalk
Using Tapatalk
