mvcap
by mvcap
FelixTheCat wrote:Almost bought a torque wrench, but then went down the rabbit hole researching...
Any recommendations for an adjustable one? Need 3nm and up
I did the same so I started this thread - some good ideas in there:
viewtopic.php?t=145686
pdlpsher1
by pdlpsher1
Monkeyfudger wrote:
Sun Jan 27, 2019 6:23 pm
A torque wrench is only ever as good as it’s calibration certificate.
I bought one of these and use it to calibrate all of my torque wrenches. These are very accurate and stay accurate. A torque wrench will have a small hole that you use a hex key to turn a screw to loosen or tighten the spring. That's how it's calibrated at the factory.
by Nefarious86
This weeks pile, replaced my dead 2-20nm wrench with the Effeto and an ATD-1 then added a 3/8 Kincrome one for crank bolts. Image
Using Tapatalk
FelixTheCat
by FelixTheCat
mvcap wrote:
Mon Jan 28, 2019 5:59 am
Appreciate the link.
Ended up buying a Raden Torque Wrench and a pair of Dura Ace pedals
calvin
by calvin
New See.Sense ACE rear light
Pop
by Pop
Darimo elipse road bar!!ImageImage
Enviado desde mi ONEPLUS A3003 mediante Tapatalk
MichaelK
by MichaelK
Pop wrote:
Wed Jan 30, 2019 8:29 am
Width and weight?
Pop
by Pop
Width and weight?
40cm, 124g!
dgasmd
by dgasmd
Width and weight?40cm, 124g!
Son of a b......
That’s impressive for sure!!!
bikeboy1tr
by bikeboy1tr
SMP composit Italian green 250mm X 130mm.ImageImage
Sent from my STH100-1 using Tapatalk
viewtopic.php?f=10&t=154188
2018 Colnago V2R Rim Brake
2012 Time RXRS Ulteam Rim Brake
2008 Time VXR Rim Brake
jsprbcn
by jsprbcn
I can't stop liking their stuff :-)
robertbb
by robertbb
bikeboy1tr wrote:
Wed Jan 30, 2019 9:13 pm
SMP composit Italian green 250mm X 130mm.[IMG]https://uploads.tapatalk-
I wish SMP would modernise their production method, similar to what Specialized, Fabric and now Giant and some Fizik models are doing. Far tidier result. Wrapping the cover over foam and stapling/gluing it underneath is so dated now it's not even funny.
bikeboy1tr
by bikeboy1tr
Haha old world Italian stuff made in Italy. This model has no foam but much to my surprise it is comfortable. There is always the full carbon model for modern looks. If they modernize these saddles they will be extremely expensive I fear.
scapie
by scapie
calvin wrote:
Tue Jan 29, 2019 3:41 pm
have you used the light yet? if so how do you rate it, particulary for daytime riding?
FilmAt11
by FilmAt11
A couple of stem options for an XC build.
Renthal Apex 80mm
Kalloy Uno 70mm
