Extralite E-Bones W ?
Been trying to find some opinions and reviews of this relatively new crankset but to no avail.
I'm aware that some on these forums, like Giant05 and Morris presently own these cranksets. How do they perform ? I've seen the gorgeous pictures but what matters more is their shifting precision and stiffness.
Also, do the weights tally ?
Thanks in advance.
Thanks in advance.
- roadrunner_gs
Here is a opinion in german.
http://www.mtb-news.de/forum/showpost.p ... stcount=18
translation:
"Yesterday I participated in a race. The weather was more terrible than i ever experienced. On climbs the chain was transportated on the smallest chainring an stucked between this and the frame - don't know if this is due to the wear of chain.
This morning i disassembled the crank from my bike and oh god there was a huge lake in the bottom-bracket. The mud was also in there. Both bearings are worn now and maybee crap soon. It seems that the seals weren't working. Also the crankarms look heavily used now, the anodization is heavily worn.
conclusion: Very light crankset but if they are good for raceconditions is to be proven by further test. Both bearings have to be replaced soon for sure (that gona be expensive!).
I wrote the report to Sergio Riva. Now the customer support of Extralite would reveal to us.
http://www.tatendrang.ch/Bike/ebones-w_crank/index.html "
But bear in mind: This is only one test from one person!
Don't transport over to other pieces of this crankset!
translation:
- roadrunner_gs
Tippster wrote:Any chance of some first ride feedback???
Look at my post.
roadrunner_gs wrote:"Yesterday I participated in a race. The weather was more terrible than i ever experienced. On climbs the chain was transportated on the smallest chainring an stucked between this and the frame - don't know if this is due to the wear of chain.
If you have a pool of water and mud in your BB shell, it's most likely entering the frame somewhere else than through the BB bearings. I noticed in some other pictures you posted on mtb-news.de that you have a Spezialized Epic with a Extralite seatpost. The cradle part of the head of that seatpost has a huge hole in it. There's also a smal gap between the back of the cradle and the post that needs to be sealed with silicone after the seat is adjusted to the correct angle. If you left both of these holes open, the water and mud that splashed up underneath your seat had direct access into your frame. And since the Epic has a standard seat tube, all that mud and water ended up right into your BB.
Don't blame the BB if you didn't seal your frame properly. Also, always drill a hole at the bottom of the BB shell, water will ALWAYS find a way into a frame. Just taking the frame out into colder weather will suck moist air in through bottle cage bolts, headset and seatpost.
As for the anodizing being worn, that always happens with anodized cranks. Sand/mud is much, much harder than anodizing, and will wear through it in no time. The only way to keep the finish good is to order silver cranks, or protect the part of the crank where your shoes will rub. I guess you can tell exactly where that is...
Sorry you had problems, though, that's not fun when you've spent all that money on nice parts. Buy new bearings, seal your frame, drill the BB, and you should be good to go.
Ole.
Ole wrote:roadrunner_gs wrote:"Yesterday I participated in a race. The weather was more terrible than i ever experienced. On climbs the chain was transportated on the smallest chainring an stucked between this and the frame - don't know if this is due to the wear of chain.
Ole.
Yes!!! I think the same...
roadrunner_gs
http://www.tatendrang.ch/Bike/epic_part ... age21.html
Does your S-works weigh 1696g with the shock?
- roadrunner_gs
It is not mine epic!
If you would have read carefully on www.mtb-news.de you would have noticed that i have mentioned the to-low weight there too!
And if you look closer you would notice that the Specialized Epic-frame ist standig on the ground with one chainstay and on the scale with the other.
And drilling a hole into a 2000 Euro frameset scares the hell out of me.
I wouldn't even do that to my 160 Euro frame!
