Very nice. What stem is that?
All Specialized Tarmacs
Moderators: maxim809, Moderator Team
New to the forum and stumbled upon this thread... some gorgoeus looking steeds on display!
Here is my custom 2012 S-Works Tarmac SL4 with the following spec:
Frame: 2012 S-Works Tarmac SL4, 56cm
Groupset: Full Shimano Ultegra 6800, Compact, 11-28 cassette (currently in the LBS having Ultegra R8050 Di2 installed!)
Handlebar: 3T Ergonova Carbon
Bartape: Specialized Bar Phat
Stem: 3T Arx Pro 130mm
Saddle: Charge Spoon Limited Edition
Pedals: Shimano Ultegra 6700 Carbon
Wheels: Mavic Cosmic Carbon SL
Tyres: 25mm Yksion Pro GripLink (front) and PowerLink (rear)
Bottle cage: Specialized Rib Cage
Nice build! I just rode a 54 Sl6 and am debating between that and the 56.
Do you happen to know the saddle height on that build? Looks like it is in the 75cm ballpark.
Thanks!
Thanks!
76,5 cmtayfromthebay wrote: ↑Mon Apr 30, 2018 8:51 pm
Still need to sort out spacers and steerer...
The saddle to bar drop on second photo looks enormous. Probably an effect of perspective, but how much of it do you run anyway?
11cm do you’re right about perspective.
Current: 2019 Specialized Allez Sprint Red Hook | SRAM Red Etap | FFWD F6R - DT Swiss 190 Ceramic hubs
Projects: 2021 TT Project | Frame Unknown | Shimano Dura-Ace Di2 | Pro Disc - TriSpoke
Eh, I run about 10cm, next time I do a photo I'll try to reproduce the perspective for a cooler look. My bike looks wonky on every photo for some reason, maybe I don't know my good angles.
- Contact:
my new ride...
2017 Specialized S-Works Tarmac SL5, 15.5 lbs/7.03 kg
Frame: 2017 Specialized S-Works Tarmac SL5, size 52
Fork/Headset: Specialized Fact Carbon with CeramicSpeed headset bearings
Crankset/Bottom Bracket: Shimano DA9000 52-36 w/ Stages DA9000 pm / CeramicSpeed bottom bracket
Pedals: Shimano DA9000
Drivetrain/Cog/Chainring/Chain: Shimano DA9000 52-36, KMC X11SL / Shimano Ultegra 6800 11-28
Derailleurs/Shifters: Shimano DA9000
Handlebars/Stem: Specialized S-Works Aerofly/ Fizik Cyrano R1 100mm, 7*
Saddle/Seatpost: Fizik Antares 00 carbon/ Fizik Cyrano 00 carbon
Brakes: ee brakes
Front Wheel/Hub/Tire:
Yoeleo SAT Superlight 60mmx25mm/ Yoeleo SL-Pro ceramic hub/ 25c Vittoria Corsa G+
Rear Wheel/Hub/Tire:
Accessories: Taxc Tao Carbon cages/ Fizik Superlight Soft Touch bar tape/ Revolutionaries 3Dprinted Fizik direct mount
Brakes: ee brakes
This is my love. The Specialized Tarmac Pro SL3 (2011, 56). Bought it slightly used in fall 2012. Got the Easton wheels during 2013 if I remember correctly. The frame and wheels compliment each other remarkably well. Right now I'm closing in on 23 000 km ridden on the frame, and have been loving every second of it. Well, a couple of seconds in serious headwinds I rather forget.
Groupset: SRAM Red eTap (SRAM Red Black edition brakeset, 11-26 cassette and 52/38 Rotor Q-Rings on a Quarq Red crankset)
Wheels: Easton EC90 SL, tubular with Continental Sprinter tubs (23/25mm)
Handlebar: 3T Ergonova LTD
Bar tape: 3T LTD
Stem: 3T ARX II Team (decals removed)
Seatpost: 3T Doric LTD
Saddle: Fizik Antares R1, regular
Computer: Garmin Edge 1000 with a F3 Cycling Form mount
Pedals: Shimano Ultegra 6800
Cable housings: mix of Jagwire Elite link and Powercordz
Upgraded from SRAM Red 2x10 to eTap during this summer. The bike feels like new again.
Weight: 6,96 kg. I was dead on 6,8 kg with Red 2x10 and Powercordz' cable housing + brake cables.
Bar tape: 3T LTD
With the FFWD F6R wheels (replaced the red decals with black ones)
