All Specialized Tarmacs
Moderators: maxim809, Moderator Team
SamD
by SamD
Swapped my 42cm Pro Vibe Aero handlebar for a 40cm x 10cm Roval Alpinist cockpit after a bike fit, and my Ultegra cranks for Power Cranks to start off the outdoor season training with power. Went from 7,8kg to 7,4kg too. Not the best pic but very happy!
LOWIEV
by LOWIEV
Hi all.
Is there anyone running the sl7 stem on an sl6 in combination with the aerofly2 bars?
I was wondering if it looked okay or wrong 😀
calleking
by calleking
6,71kg. Best bike I ever had in many aspects. Sadly have to let her go :cry:
2016 CAAD12 SRAM Red 22 Enve SES 4.5
Retired:
2018 S-Works Tarmac SL6 Sagan Superstar DA 9150
2016 Aeroad CF SLX UDi2
aqualelaki
by aqualelaki
SamD wrote:
Mon Feb 22, 2021 10:16 pm
Looks very clean. What's that at the back of the saddle? Some kind of SWAT attachment?
thedanplasse
by thedanplasse
It's coming along.
2018 Specialized Tarmac Expert Sl5
2017 Cannondale Slate Ultegra 1x
SamD
by SamD
aqualelaki wrote:
Sun Feb 28, 2021 11:30 pm
Thanks! Indeed, 3D printed, for my Bontrager Flare RT light. You can find it here. Albeit if I'd buy again I'd probably buy the stealthier one.
dif
by dif
Thanks for sharing. What is the measurement from your bottom bracket to the top of the saddle on your new SL7?
kppolich wrote:
Thu Feb 04, 2021 9:14 pm
SL6 SOLD
SL7 Current
kppolich
by kppolich
785mm Center of BB to top of saddle
170mm crank length, 56cm SL7, 110mm (6 degree) stem.
mvcap
by mvcap
HTS888 wrote:Just finished my paint and Groupset refresh of my 2010 Tarmac SL3 Project Black, 6.75kg without speed plays 6.95kg with pedals. I love this bike due to external cabling and project black was quite limited at the time...I don't have the individual weights but part list below
Sworks SL3 56
Campy 12 speed Record mechanical
Campy Hyperons tubular 22mm
Conti pro limited tub tyres
Sworks stem 120
Sworks shallow drop bars
Sworks seat post
SelleSan Marco shortfit saddle
Selle matching bar tape
CBear BB
Nokon cable kit
HTS888 would you mind sharing the name of that paint? I love it! Nicely done
Sent from my Pixel 3a using Tapatalk
bruno2000
by bruno2000
Somebody has a real life picture of the Tarmc SL6 in Granite blue.
I wonrder if the logo on the downtube stands out a lot or is it mostly a 'black' frame?
Is this paintsheme heavy?
bruno2000
by bruno2000
Just for those interested, I've got the Tarmac SL6 s works disc granite blue grey color.
Size 56 is 865gr.
junchen
by junchen
I have a Tarmac sl6 disc which is rated for max 30mm tire clearance.
For Zipp 303s with int diameter of 25mm, has anyone tried using schwalbe pro one tubeless 28mm? Is there sufficient clearance?
Thanks
sychen
by sychen
junchen wrote:I have a Tarmac sl6 disc which is rated for max 30mm tire clearance.
Thanks
Pretty sure that's a yes... Had 28mm tyres measured at 31mm on 21mm internal rims that had heaps of clearance..
Sent from my Pixel 4 XL using Tapatalk
Dannnnn
by Dannnnn
Thanks
Same as this. I use 28mm S-Works Turbos on CL50s come up at 31mm and have no clearance issues
Sent from my Pixel 5 using Tapatalk
tbabut
by tbabut
I'm still loving my SL5 :)
Image20210330-L1005829 by Thomas Babut, on Flickr
20210330-L1005844 by Thomas Babut, on Flickr
