All Specialized Tarmacs
Moderators: maxim809, Moderator Team
Klaster_1
by Klaster_1
Ritsuke wrote:
Tue Nov 03, 2020 11:47 am
What's that derailleur hanger and what are de advantages? Bigger cassette?
Looks like a Sigeyi Shimano direct mount hanger, it's lighter than a stock setup with separate bracket axle unit and hanger. I find DM hanger look cleaner too.
thedanplasse
by thedanplasse
Klaster_1 wrote:
Tue Nov 03, 2020 11:58 am
Bingo, Also I find the shifts to be a little more crisp with it. They didn't have it in black when I ordered it, but it matches with C-Bear oversize pulleys, and bottom bracket.
2018 Specialized Tarmac Expert Sl5
2017 Cannondale Slate Ultegra 1x
Ritsuke
by Ritsuke
Allright, awesome, thanks for the feedback @Klaster_1 and @thedanplasse
Current
2019 Specialized Allez Sprint Red Hook | SRAM Red Etap | FFWD F6R
2021 S-Works Tarmac SL7 | Shimano Dura-Ace Di2 | Roval CLX Rapide
Projects
2022 TT Project | Frame Unknown | Group Unknown | Pro Disc - TriSpoke
Euch
by Euch
thedanplasse wrote:Bingo, Also I find the shifts to be a little more crisp with it. They didn't have it in black when I ordered it, but it matches with C-Bear oversize pulleys, and bottom bracket.
Happy with the oversize pulleys from C-bear? I was thinking of getting them for my SL7 (with SRAM Force AXS). Do you have hybrid or full ceramic. Do you know if you have to do regular maintenance on them (and on the BB)? Is there an instruction sheet/video that you know of? The price for 2 little wheels still got me in doubt Image The BB is not especially expensive.
thedanplasse
by thedanplasse
Euch wrote:
Tue Nov 03, 2020 8:38 pm
I love them, everything is much smoother. Full ceramic. I'll pull them off at the end of the road season, and clean/lube them. Along with the BB.
C-Bear is great, and much more affordable that Ceramicspeed. (fairweather cyclist too, so they don't see much inclement weather)
Euch
by Euch
What do you lube them with? I will usually take my good bike out only with good weather, but you can't avoid an occasional splash in Belgium Image
thedanplasse
by thedanplasse
I haven't gotten that far yet, I'll figure that out when the bike becomes an indoor bike for a few months.
Ritsuke
by Ritsuke
Euch wrote:
Tue Nov 03, 2020 8:45 pm
Use the same lube as CeramicSpeed advises? Will work for C-Bear as well.
https://www.ceramicspeed.com/en/cycling ... -bearings/
Current
Projects
thedanplasse
by thedanplasse
thanks for the info! I'll be buying a bottle soon.
Euch
by Euch
Yup, but they also advise to take the bearings apart (remove seals, degrease and regrease) every 5-8000km (for BB) with this: https://www.ceramicspeed.com/en/cycling ... nd-grease/
Fyi, some info from CeramicSpeed
https://www.ceramicspeed.com/media/4605 ... enance.pdf
KarlC
by KarlC
Euch
by Euch
Custom painted SL7, a thing of beauty in my humble opinion.
djel
by djel
Picked up Tarmac frameset at my LBS and swapped the parts I had on my Izalco.
7.51kg as is, which is a bit more porky than I expected. I'm looking at buying a lightweight set of wheels that would save me around 3-400g over my AR56. The cockpit is less than 375g and I'm not sure there is much room for improvement without going exotic.
HTS888
by HTS888
Just finished my paint and Groupset refresh of my 2010 Tarmac SL3 Project Black, 6.75kg without speed plays 6.95kg with pedals. I love this bike due to external cabling and project black was quite limited at the time...I don't have the individual weights but part list below
Sworks SL3 56
Campy 12 speed Record mechanical
Campy Hyperons tubular 22mm
Conti pro limited tub tyres
Sworks stem 120
Sworks shallow drop bars
Sworks seat post
SelleSan Marco shortfit saddle
Selle matching bar tape
CBear BB
Nokon cable kit
kppolich
by kppolich
SL6 SOLD
SL7 Current
