Colnago C50 - NL12
majklnajt
by majklnajt
Thanks gentleman! :thumbup:
majklnajt
by majklnajt
The geometry of the frame again here:
"Size 57"
Tup tube: 556 mm
Head tube: 158 mm (between headset cups)
Seat tube: 592 mm (center of BB to top - seat clamp included); 580 mm (center of BB to underside of the seat clamp)
Wheelbase: 998 mm
anquetil
by anquetil
I think size is 58.
majklnajt
by majklnajt
It very much looks like really is 58, yeah.
The red P for the traditional frame should be 57, mine is 58. Everything else is as size 57.
Colonia
by Colonia
Well, I think it is settled. The frame is basically a 58. It might have a shorter top tube, assuming the top tube was measured right (which is tough to do).
The head tube measure isn't all that odd, because Colnago headtubes were shorter up until about 2006. My 2005 Extreme-C is a 57cm frame but has a 15 cm head tube. Vintage or vintage style frames like the Master are even shorter in the same size.
SalsaLover
by SalsaLover
majklnajt wrote:I still sometimes think that the sadlle is too low for this frame, when looking at it from different angle. But sometimes I think its perfect! :D
Stem is 110 mm. Sadlle height 75 cm. Seat tube center to top: 59
Looks like you have a 58
I have similar measurements as you, I am 1.80 and my saddle height is 74.5 as I have relatively short legs.
I ride a 56cm C50 with a 120mm stem, seatpin lenght including saddle is 17cm.
my Extreme Power is a 54cm with a 130mm stem, setup identically and the seatpin lenght is 19cm.
my stems are -6° though.
The EP feels faster and nimble, but the C50 is more stable and comfortable. I did tried a 57 and a 58 on a 110 stem but they felt sluggish in comparison to the other 2.
Hucken The Fard Up !
Colnagos : C50 ST01 - Master 30th AD10 - C40 Mapei WC
majklnajt
by majklnajt
But if it would be a standard 58, it would have 56,5 cm top tube ;)
Calnago
by Calnago
Sorry, initially posted this in the Colnago Pics thread... this is a better place for it.
Damjan, You'll probably never know for sure why your bike doesn't perfectly match up to any Colnago standard geometries. If your measurements are correct, it is closer to a 57 than a 58, with that one glaring exception of the longer seat tube, which does absolutley nothing to change the handling, fit, etc. So I have no idea why anyone would intentionally order just that one change. Perhaps they just built up a 57 with 58 seat tube by mistake. Mistakes do happen after all. Don't know.
But just due to the psycological havoc this whole issue is wreaking on you, maybe it's time to treat yourself to nice new matte black bike, tan sidewalls, and find yourself a girlfriend just like the one walking with that beautiful L'Eroica frame in the other thread.
majklnajt
by majklnajt
Yeah, fat as a pig :D
This means my frame has even higher value because it is unique!! :beerchug: :D :D
irongatsby
by irongatsby
Hi Salsalover, what handlebars do you use on both bikes? Also, do you run Campy and setback seatposts?
SalsaLover
by SalsaLover
irongatsby wrote:Hi Salsalover, what handlebars do you use on both bikes? Also, do you run Campy and setback seatposts?
I use 3T Rotundos, and full Campagnolo 11, setposts are the Colnagos so I think it is 25mm ?
I will take better pictures tomorrow and post them
majklnajt
by majklnajt
FRAME-SET SOLD !
Willier
by Willier
Aleluja! :thumbup: What now?
majklnajt
by majklnajt
You`ll see ;)
Rumsas
by Rumsas
Looking very much forward to seeing your next build.
Any hints, about whats coming ??
