I submit the three that I have.
RaceFace evolve (for test purposes
Token MTB 68mm with 3 spacers
Token Road 68mm with SKF bearings (no spacers)
RF 114g (107g for cups)
Token MTB 99g (93g for cups)
Token R-SKF 91g (85g for cups)
The question I have is. Is there a difference between the road and mtb bb? other than the sleeve and maybe one or two spacers If you are not using the sleeve, wouldn't they be exactly the same?
From what I see in front of me, the only difference is, that the MTB cups have 1-2mm more threading than the road on the R cup and 2-3more on the left cup. Adding in the spacers and the road cup still has enough room to fit on my bb.
The integrated evolve crank went right through the road cup and seemed to fit snug.
So for those that are looking to replace your deus or xtr with a lightweight alternative with very smooth bearings (SKF) I would check out the token. I may stick with this one folks
