Alpina Hyperlight Spokes
Forum rules
I've seen brands offering these out on lots of different wheelsets as an alternative to cx-ray; on wheelsets for road, gravel and MTB.
Has anyone got any experiences on them in terms of robustness against their competitors? (DT aerolight, cx-ray)
I have just built a wheelset for myself using Alpina Hyperlite and Extralite Aero. Only rode it for a few hundred km so far, so can't really say anything about durability. I can just tell you they look and feel like their Sapim equivalents. Only Extralites are a bit beefier than CX Sprints.
However, since they cost only about half of what sapim charges, I had to give them a try
Same here. Build another set yesterday with the hyperlites.Petz wrote: ↑Fri Nov 15, 2024 2:23 pmI have just built a wheelset for myself using Alpina Hyperlite and Extralite Aero. Only rode it for a few hundred km so far, so can't really say anything about durability. I can just tell you they look and feel like their Sapim equivalents. Only Extralites are a bit beefier than CX Sprints.
However, since they cost only about half of what sapim charges, I had to give them a try![]()
I think metal spokes from major brands are composed of the more or less the same material and processing? So... spokes having similar profile and weight should have similar properties...
so what are the metallurgy applied to Super CX Ray and Hyperlite?
The diameter of the spokes ends are 2mm(hyperlite) and 1.8mm(super cx). My builder says Hyperlite transition section has been thickened and reinforced.
sworks sl8 rtp 56 5.77kg
specialized crux udh 56 7.48kg
retired:
factor ostro vam 56 6.15kg
specialized allez sprint 2023 7.13kg
specialized sl7 56 6.75kg
retired:
Nice spokes, good feel when building a wheel. Very linear response. Highly recommended that the rim bed has spoke holes. Use something like Sapim Double Square nipples
If you like to work with the SPOKEY spoke wrench, you will be holding the spoke too far away from the nipple and it will twist
Need the DT Swiss TTSXXXXR05664S spoke wrench and their holder to build or adjust spokes from the hub side
Giant TCR Adv SL '23 (6.1) · BH Lynx Race Evo '19 · Seraph GR029 '21 (7.7) · Canyon Inflite AL '14
And if you assemble on rims without holes? Will it be much more difficult? I thought about buying AR25 rims without holes, H-works hubs and assembling wheels on them.Aeo wrote: ↑Tue Dec 10, 2024 10:23 amNice spokes, good feel when building a wheel. Very linear response. Highly recommended that the rim bed has spoke holes. Use something like Sapim Double Square nipples
