I am looking for a possible build around this Cannondale Supersix Evo CX SE frame:
https://www.cannondale.com/en/bikes/roa ... et-c11381u
...but I see that it has a PF30 bottom bracket (and that it has a wider Q factor of +10mm if I trust some reviews on Youtube).
Can I still use a Shimano Dura Ace 9100 crankset with this frame?
(maybe with some adapters)
PF30 BB with a Shimano Road crankset? (Cannondale SuperSix Evo CX/SE)
This has the AI offset as well, so keep in mind for a build you'd need the specially dished wheels.
Thanks for pointing that!raisinberry777 wrote: ↑Mon Nov 11, 2024 11:10 amThis has the AI offset as well, so keep in mind for a build you'd need the specially dished wheels.
Well, I will pass on that frame.
The crank wouldn't be an issue at all, it's the AI offset that would also be the deal breaker for me.
