Tires for tarmac and sand
Gang, the area I live in has some pretty crappy tarmac roads and loads of sandy "off-roads" (all pancake flat, think 1m/1km elevation). What do you think are the best tires for such conditions? Am I right to think that tire pattern does not matter here, what is important is width and width only?
2020 Scott Addict RC / 2023 Specialized Tarmac SL8 / 2024 S-Works Crux
Conti TerraSpeed 35mm if your bike could fit 35mm tires. I assume you’re not asking for a true gravel tire for deep sand. The TerraSpeed will handle sand as long as it’s not deep sand. TerraTrail is also an option as it has bigger knobs, but slower rolling on tarmac.
It's an S-Works Crux with 48mm clearance. So plenty of room for a 35mm, probably even will look skinny. Right now I run Maxxis Velocitas, WAM 42mm. I wonder if there are better options.pdlpsher1 wrote: ↑Thu Nov 07, 2024 6:11 pmConti TerraSpeed 35mm if your bike could fit 35mm tires. I assume you’re not asking for a true gravel tire for deep sand. The TerraSpeed will handle sand as long as it’s not deep sand. TerraTrail is also an option as it has bigger knobs, but slower rolling on tarmac.
Indeed. I once crashed on a hard-packed-dirt surface with a very light coat of sand on top of it. The sand acted like roller bearings and my front tire just slid out without warning.
I'm unsure what the OP meant by "sandy "off-roads"".
There's never a perfect gravel tire for all road conditions. My personal gravel tire philosophy is to use the lowest RR tire possible and just go slow when the road conditions get challenging. I'd rather be faster on the flats and climbs, than be faster on descents but slower on flats/climbs. I don't race so downhills don't matter to me.
