Hey all,
Anyone explain the new flight attendant? Does it have to work with transmission?
I have a 2023 Blur with Sram axs.... I also have a Sream Quarq power meter on it. Im wanting to upgrade the bike but not really sold on transmission.
Can I get flight attendant to work with AXS and the quarq power meter? Will the flight attendant pedal sensor fit the eagle axs cranks or is it needed?
Thanks a bunch!
Flight Attendant
- Curious George
Flight attendant requires the use of either a Quarq powermeter or the SRAM pedal sensor.
T-Type transmission is not required for the system to work.
Bit the bullet and hit LBS to order flight attendant fork and shock. I'll be running it with my Eagle AXS and Quarq pm.
Will the system run the same as with transmission... will I miss any features by not using it with transmission?
Would getting a transmission controller LHS be benificial to be able to control the suspension or is auto mode fine?
Anyone with flight attendants comments would be awesome!
Cheers
Cheers
