Travel with electronic shifters
How can I make sure the shifter batteries don't drain when the bike has been packed up and something moves in the bag and presses one of the shifter paddles?
It's happened to me before on a trip and is really annoying.
If I take batteries out will wireless shifters need to be re-paired?
It can be worse than that. SRAMRed 22 11 sp. have a wakeup function that turns the shifters on, when the bike is moved!!
Cannondale Super Six Hi Mod 2017 6.845 kg
Cannondale six13, 2004, 5.50 kg
Focus Izalco Max, 2023, 4.33 kg
I think SRAM AXS 12 speed also has a 'shake to wake up' function. I don't see a travel mode on the app.poulhansen wrote: ↑Thu Oct 31, 2024 1:03 pmIt can be worse than that. SRAMRed 22 11 sp. have a wakeup function that turns the shifters on, when the bike is moved!!
I guess this means it's necessary to remove the batteries before travelling.
Not seen rechargeable coin cell batteries for shifters.
How long are you flying? Max 20hrs? Think riding the bike for 20hrs and you don't even think about draining the coin cells on the shifters. Get new batteries before your flight and that's it. Don't worry.
I have those but only use them when no primary batteries in the house. They are too unreliable and standard CR2032 are very small.Nickldn wrote: ↑Tue Nov 05, 2024 12:08 pmNot seen rechargeable coin cell batteries for shifters.
