Ridley ASTR RS
treyxt
by treyxt
Requiem84 wrote:
Sun Nov 17, 2024 4:48 pm
cerro wrote:
Sun Nov 17, 2024 4:30 pm
Requiem84 wrote:
Sat Nov 16, 2024 7:48 pm
Another downside are the fork/handkebar dimensions (or however you call it). It's 1.1/4 instead of the usual 1.1/8.
I suppose that rules out many other nice handlebar options? What would be a good alternative to the stock Nimbus cockpit?
Isn't that just the bearing to get space for everything? The fork should be regular Ridley D-shaped so alla cockpits that work with that should work. Or I'm screwed ;)
According to the technical specs it's the headset dimensions.
See here:
https://imgur.com/a/HveJBpy
But they list the Deda Super Box (which is for 1-1/8 steerer) as the stem spec'd on the normal Astr? https://www.ridley-bikes.com/en_US/bikes/SBIASTRID023
Specialized Tarmac SL7 10r 61cm (Raw Black Carbon) / r9170 Dura-Ace Di2 11sp / Lightbicycle AR46
Cannondale SuperSlice Hi-Mod 58cm (From EF) / r8050 Ultegra Di2 11sp / AeroCoach Ascalon Carbon / AeroCoach AEOX Zephyr
cerro
by cerro
See here:
Headset and Fork dimensions are different. I got 1,5" upper headset bearing on my gravelbike now which has a normal round 1 1/8 tapered fork :)
treyxt
by treyxt
Messaged a local dealer in the USA about availbility. Anyone know what the price of a regular Astr frameset is in the USA?
Requiem84
by Requiem84
treyxt wrote:
Sun Nov 17, 2024 5:07 pm
See here:
That's confusing, as I presume it should be the same between the RS and non-RS?
Perhaps good to ask Ridley directly...
sunfire2k5
by sunfire2k5
Requiem84 wrote:
Mon Nov 18, 2024 2:05 pm
See here:
Iam 99.9% sure that they us the same d-shaped steerer like all their other bikes. Its 1 1/8 diameter.
FOIL 30 MY23, Ult+105 Di2, EXS Aerover 120/360, Newmen Allround Vonoa
Ridley ASTR RS - GRX Di2 2x12 - Nextie AGX45 - Terra Speed 45mm
Ridley X-Night RS GRX+105 Di2 1x12s
Requiem84
by Requiem84
sunfire2k5 wrote:
Mon Nov 18, 2024 7:11 pm
See here:
But am I then misunderstanding their own Astr RS technincal documentation, or did they make a mistake in their documentation?
treyxt
by treyxt
Requiem84 wrote:
Mon Nov 18, 2024 7:16 pm
I confirmed it's a normal 1-1/8 steerer.
Also, $2995 in united states for the Astr frameset! More than I had hoped.
cerro
by cerro
They don't mention the forksize in the technical documentation. Just the bearingsize
sunfire2k5
by sunfire2k5
They use a big plastic "spacer" to center the fork inside bearing. Its 1 1/8 fork/steerer.
Iam thinking about ASTR with Grx 2x12 and upgrade to xplr 13 in march.
Requiem84
by Requiem84
sunfire2k5 wrote:
Tue Nov 19, 2024 4:58 pm
Thanks for clearing it up!
spdntrxi
by spdntrxi
yes... 1 1/8 is ok.. back in the market
2024 BMC TeamMachine R
2002 Moots Compact-SL
2023 Pivot E-Vault x2 drop and flat bar
sunfire2k5
by sunfire2k5
I just could not resist RS version in stock in the best looking paintjob. Will arrive next week with Di2 12s GRX and DT Swiss GRC1600 wheels...
Requiem84
by Requiem84
VERY curious to hear how you like it.
sunfire2k5
by sunfire2k5
Requiem84 wrote:
Sat Nov 23, 2024 3:30 pm
Ice and cold in Norway now... lets see if I get any trips outside. 50mm studded tires will fix atleast 😉
LeDuke
by LeDuke
cerro wrote:
RotterdamNL wrote:
Sat Nov 02, 2024 5:16 pm
spoke to Redley dealer yesterday. Indeed, its possible to order frame in basic colours without having to pay extra 400-500 eur for custom paintwork. Frame gonna be deliverd before christmas.
It is not possible to test Astr in the wild. Around january dealers will get showroom models, but again, no test riding option availible.
About tire clearence it is unclear that 50mm tires will fit with 2-by built, probably not.
I really like Astr and it is always nice to have official dealer nearby, but lack of internal storage, fender mounts and only 47mm clearence in 2-by is big no go for me, also considering that frame cost 2300 eur even without seatpost
Test ride or not depends on dealer I would say.
fender mounts on a racebike?
Some of us do longer races than others.
