Most AERO bottle solution.
I would like to know what is the most aerodynamic solution for my bottles.
It will be approx 45min Crit race. 45km/h+ average so nutrition on the bike is not critical.
The bike. Felt AR advanced Disk.
The bottles. Elite Crono CX TT bottles with carbon cages.
The diwntube of thr Felt is a VERY narrow kammtail. The bottles are SLIGHTLY wider than the down tube. And then a fair bit wider than the seat tube.
What would be best?
No bottles?
Or attempt to fill the frame up with the bottles?
Here is a pic of the bottle on the diwntube. And then the seat tube bottle
What would be best?
No bottles?
A backbottle in your jersey would be my suggestion.
Or some bottleholder mount attaching to your saddle.
Road
Cube Agree C:62 SLT 2021 (frame+fork) DA 9270 6.9x kg - ride-ready 7.25 kg w/pedals, cages, sensors, Wahoo mount
Gravel
Velobuild GF-002 Force AXS 7.5 kg, ride-ready 7.775 kg w/200 ml Stan‘s, pedals, cages, sensors, Wahoo/Cateye mounts
Gravel
Please do not attach any bottle under your saddle for crit racing, I have seen them to have a much higher chance of dropping a bottle than in traditional locations.
For crits (in the UK mind) I've never found a need for a bottle but I would probably go for a soft flask in a back pocket as I would imagine at most you would have 2-3 drinks and this will affect your aerodynamics less
Not sure I agree with this. Of course it depends on the frame, but an aero bottle on DT fills in space and will generally be faster. I run an empty bottle on 10 mile TTs and the Cannondale aero bottle empty in crits (on a systemsix) for this reason.
The seat tube however is pretty much always a penalty - unless you've got a complete system like the new madone.
Didn't you read the OP's description on tube shape? Aeroach has already shown data on such tube shape.gloscherrybomb wrote: ↑Thu Oct 10, 2024 3:42 pmNot sure I agree with this. Of course it depends on the frame, but an aero bottle on DT fills in space and will generally be faster. I run an empty bottle on 10 mile TTs and the Cannondale aero bottle empty in crits (on a systemsix) for this reason.
Cannondale aero bottles or the better Trek ones require a fluent transition from DT to bottles.
That's not true: according to both Trek and Cannondale their bottles test faster on every frame they tested including round tubes. Trek even went so far as to claim they saw about the same amount of aero gains with their bottles on every frame they tested.alanyu wrote: ↑Thu Oct 10, 2024 7:32 pmDidn't you read the OP's description on tube shape? Aeroach has already shown data on such tube shape.gloscherrybomb wrote: ↑Thu Oct 10, 2024 3:42 pmNot sure I agree with this. Of course it depends on the frame, but an aero bottle on DT fills in space and will generally be faster. I run an empty bottle on 10 mile TTs and the Cannondale aero bottle empty in crits (on a systemsix) for this reason.
1. Saving compared to "round bottles" on "a range of bikes" . OP asked for fastest optionnigel379 wrote: ↑Fri Oct 11, 2024 6:25 pmThat's not true: according to both Trek and Cannondale their bottles test faster on every frame they tested including round tubes. Trek even went so far as to claim they saw about the same amount of aero gains with their bottles on every frame they tested.alanyu wrote: ↑Thu Oct 10, 2024 7:32 pmDidn't you read the OP's description on tube shape? Aeroach has already shown data on such tube shape.gloscherrybomb wrote: ↑Thu Oct 10, 2024 3:42 pmNot sure I agree with this. Of course it depends on the frame, but an aero bottle on DT fills in space and will generally be faster. I run an empty bottle on 10 mile TTs and the Cannondale aero bottle empty in crits (on a systemsix) for this reason.
2. CFDed, not tested.
The OP asked for advice for a crit.
Please do not suggest he puts the bottle behind the saddle. If you're not sure what a crit is, I'd research that, first.
The Trek aero bottle solution is probably your best bet. For a 45 min crit, it won't matter much.
I just installed the RSL cages on my 54cm Gen 6 Madone and will probably take them off. It is very difficult to remove the ST bottle and 750mL Purists do not feel very secure in their place. 650mL Purists seem okay, but the 750s get top heavy and can roll out sideways.
I may put them on for crits and run an empty ST bottle.
Maybe 1 - 3 of these package filler air pillows in the back pockets would be an even better (lighter) solution provided water is not required?
But yeah, they'd probably be better suited to like a hillclimb TT or similar.
Has anyone experimented with those?
'24 S-Works Tarmac SL8 RTP|Ultegra R8100|Alpinist CL / Custom Rapide CLX 2x60
'19 Diverge E5 Comp
'23 Epic Pro LTD
'22 Status 160
'19 Diverge E5 Comp
'23 Epic Pro LTD
'22 Status 160
I use the RSL cage with Elite Fly bottles and they fixed great. No rattle or other noices at all, also fine on pave as well.TobinHatesYou wrote: ↑Sat Oct 12, 2024 6:49 amI just installed the RSL cages on my 54cm Gen 6 Madone and will probably take them off. It is very difficult to remove the ST bottle and 750mL Purists do not feel very secure in their place. 650mL Purists seem okay, but the 750s get top heavy and can roll out sideways.
One downside, they squizzed a bit to much when in cage, so may change for new bottles may one‘s in a saison…
